8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible), 67 guests, and 1 robot.
Topics128,090
Posts1,056,014
Members48,430
#117776 09/28/2005 10:24 PM
Does anyone know how thick AD sheet metal is? I want to get the right welding wire to repair some holes in my truck. Thanks
#117777 09/28/2005 10:32 PM
Shipwright,
Some cab corners I have are touted as being 19ga which is around .044 thick. Your probably going to end up with .024 wire, which is about as small as it gets.
Stuart.
#117778 09/28/2005 10:53 PM
19 gauge is correct throughout, to the best of my knowledge.
~ Kimberly
My '54 ... and my '63 and a '59 F100
#117779 09/29/2005 2:40 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have used both .025 and .030 wire on AD sheetmetal. Both seem to work fine. If you have some holes you plan to fill I would suggest .030 and a piece of copper to "back" the weld. Helps reduce the heat build up in the metal.
#117780 10/05/2005 1:24 AM
There was a posting somewhere about the metal gauge. The answer that I remember was that the external sheet metal is 19 gauge and the floor is 16 gauge.
1951 1 Ton Completed
