| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Does anyone know how thick AD sheet metal is? I want to get the right welding wire to repair some holes in my truck. Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Shipwright, Some cab corners I have are touted as being 19ga which is around .044 thick. Your probably going to end up with .024 wire, which is about as small as it gets.
Stuart. | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | 19 gauge is correct throughout, to the best of my knowledge. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I have used both .025 and .030 wire on AD sheetmetal. Both seem to work fine. If you have some holes you plan to fill I would suggest .030 and a piece of copper to "back" the weld. Helps reduce the heat build up in the metal. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There was a posting somewhere about the metal gauge. The answer that I remember was that the external sheet metal is 19 gauge and the floor is 16 gauge. | | |
