2 members (55shaker, 1 invisible), 55 guests, and 2 robots.
Topics128,076
Posts1,055,920
Members48,429
#1176546 08/02/2016 8:46 PM
Installing new tie ball studs on a '49 3600 and need torque. Probably in the manual but I can't find it. Anybody know?
Dave
I am thinking the bolt in ball studs are aftermarket, so you will not find the torque value. GM peened the ball studs in except for the 55-59 trucks which used the more modern tie-rods.
Here is the last page of the '55-'59 GMC shop manual, steering section.
http://chevy.oldcarmanualproject.com/gmc/5559mm/5559mm011.html
Here is the start of the tie-rod section,
http://chevy.oldcarmanualproject.com/gmc/5559mm/5559mm009.html
Okay. Thanks. I had torqued to 60#'s so guessed right.
Dave
