8 members (Otto Skorzeny, MickeyP, JW51, Gdads51, chevy51truck, LAROKE, TUTS 59, Oswald),
88
0
Mod | | | Forums66 Topics128,049 Posts1,055,698 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 40 | Hello,
According to Chevys of the 40s their Okie bushing supplier has been bought and the new owner is not currently manufacturer these. I'm assuming Jim Carter had the same supplier because their web site lists the Okie bushing as on back order. Does any one know of a source?
Thanks, John | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | 1951 3100
I ordered one from them back in May. Girl called and said it may be 1 or 2 months before they had any. So if this is the case, then this sounds like I'm not going to get mine.
Mike
Mike
1951 3100 5 window
| | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | If I'm looking at the right part, The Filling Station has some, shown as 'limited supply' for the 1937-39 and 1940-50 parts, while 1951-54 do not have the limited supply note. | | | | | Joined: Nov 2015 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 40 | Thanks EBS,
I will check the Filling Station out. My other idea was to just install a second original seal and bushing up against the old one. That would would locate it on an unworn section of the drive shaft.
John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have never seen the seal area show much wear on the shaft. The bushing area is the problem. The Okie puts the new bushing ahead of the old rear bushing on an area never used before.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2015 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 40 | Hi Dave,
Right, the seal area is not the problem but if I install a second seal and a second bushing I am in effect doing the same thing that the Okie bushing will do correct? Unless there is a difference in the torque tube ID.
John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Yes, the ID of the tube changes ahead of the rear bushing.
What year is your torque tube?
John | | | | | Joined: Nov 2015 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 40 | Sorry for the repeat post. My truck is 1940 1/2 ton. | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | 1951 3100
So, let's see if my logic is correct on this. According to the specs of the Okie bushing for my year truck, which are listed on FS's site, ID and OD of one end is a shade smaller than the ID and OD of the other end, and the smaller end has the seal incorporated in it. This tells me the smaller end would go in first, and you would drive the bushing in until it's flush with the end of the tube. This puts the seal facing the rear end. Which tells me there is no seal at the end of the tube facing the transmission. But there would be no need for a seal there anyway. All we're concerned about is the oil NOT going down the tube to the rear end, and the shaft staying straight and true.
I have not seen the actual bushing, other than the pictures on the sites, so I'm not sure of the design. Once I have it in my hands, I'll know how it goes.
I measured my tube last night, as best I could with a caliper, and after looking at the Okie bushing specs, all should fit snug. I have seen on here before where people had all kinds of problems installing the bushing and having to drive it in with a BFH and all that. I don't mind using a hammer to make it go, but if I have to keep increasing hammer size, something ain't right.
Mike
Mike
1951 3100 5 window
| | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I've been waiting for an okie bushing from Jimmy Carter for half a year. Each time I ask them I hear it will be two more weeks. Can anyone verify if The Filling Station actually has them? Otherwise are we outa luck?
Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | After reading the issue about C of the 40's, I sent an email to them regarding my 2 month old order for one. About 30 minutes later, I got a phone call from them. She confirmed what was said. So I cancelled my backorder and will go with FS I suppose. We'll see how that goes. Must say I was impressed somebody called, and she was very nice about it also. I figure it ain't her fault. I've been in the supply chain now for 37 years, I understand.
Mike
Mike
1951 3100 5 window
| | | | | Joined: Nov 2015 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 40 | I'm thinking there is an opportunity here for someone with a CNC lathe to make some money. Unless the part is patent protected. | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I'll order one. Maybe even two. It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
