3 members (TUTS 59, Phak1, Pre '68 Dave), 196 guests, and 3 robots.
Topics128,095
Posts1,056,067
Members48,433
#1175395 07/25/2016 6:52 PM
Looking for a source for 6 volt 1157 light bulbs.
I will appreciate your assistance.
Harold
Harold
Harold an 1157 comes back as a 12 volt bulb. do you want an 1158 which is 6v? if so - they have them on Amazon,...
The 6 volt dual filament brake/tail light bulbs are #1154- - - - -plenty of them on Ebay right now.
With this information I'd check the local parts house. If no luck there perhaps and older one that's been in the same location for a while. Save the shipping!!!
Thanks guys,
I know about the 1154 & the 12V 1157. The 1158 is the same C.P. as the 1154.
The C.P. on the 1154 is 21/3 while the 1157 (12V) is 32/3. I was told the 1157 came in 6V but this info. was apparently wrong.
Was trying for a brighter stop light W/O going to LED's. Guess I'll stick with the 1154's.
Harold
Harold
Ex Hall Monitor
Ex Hall Monitor
Double posting isn't good. I'll delete the your other on the same subject. On topic, spray paint the inside of your housing gloss white if you haven't already. Also make sure you're using plastic lenses, they let more light through than the glass lenses.
Tiny,
I do not believe this is a double post. This post was asking for a source. The other post is asking for a determination of candle power. I see it as 2 different subjects. I think you should have given me an opportunity to explain before deleting my post. Now there is no way to get the answer I want.
Harold
Harold
Ex Hall Monitor
Ex Hall Monitor
Two posts about the same bulb, both discussing candle power. Nuf said. FYI the 1158 is not a 6v 1157 equivalent. It has parallel ears on the base where the 1157 & 1154 are offset. They require different sockets.
Harold, I sprayed the inside of my 37 tail lights with some mirror type paint and gained some brightness that way. Been running them for years now.
Alvin,
Mine are painted with a very bright & reflective silver.
My question regarding voltage on C.P. will go unanswered because it was deleted before it could be answered.
Harold
Harold
http://www.1954advance-design.com/Documents/6v12vBulbs.jpg
Same 6v and 12v bulb "equivalent" codes/numbers are show at the above link.
Nice chart.
Harold
Harold
