| | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Looking for a source for 6 volt 1157 light bulbs. I will appreciate your assistance. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | Harold an 1157 comes back as a 12 volt bulb. do you want an 1158 which is 6v? if so - they have them on Amazon,... | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The 6 volt dual filament brake/tail light bulbs are #1154- - - - -plenty of them on Ebay right now. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | With this information I'd check the local parts house. If no luck there perhaps and older one that's been in the same location for a while. Save the shipping!!! | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks guys, I know about the 1154 & the 12V 1157. The 1158 is the same C.P. as the 1154. The C.P. on the 1154 is 21/3 while the 1157 (12V) is 32/3. I was told the 1157 came in 6V but this info. was apparently wrong. Was trying for a brighter stop light W/O going to LED's. Guess I'll stick with the 1154's. Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Double posting isn't good. I'll delete the your other on the same subject. On topic, spray paint the inside of your housing gloss white if you haven't already. Also make sure you're using plastic lenses, they let more light through than the glass lenses.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Tiny, I do not believe this is a double post. This post was asking for a source. The other post is asking for a determination of candle power. I see it as 2 different subjects. I think you should have given me an opportunity to explain before deleting my post. Now there is no way to get the answer I want. Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Two posts about the same bulb, both discussing candle power. Nuf said. FYI the 1158 is not a 6v 1157 equivalent. It has parallel ears on the base where the 1157 & 1154 are offset. They require different sockets.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Harold, I sprayed the inside of my 37 tail lights with some mirror type paint and gained some brightness that way. Been running them for years now. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Alvin, Mine are painted with a very bright & reflective silver. My question regarding voltage on C.P. will go unanswered because it was deleted before it could be answered. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
