Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Donf, Wickedbass, Wally / Montana, TexasA&M48Truck, FAST55, Chester2392), 42 guests, and 4 robots.
Topics128,010
Posts1,055,298
Members48,419
#1173890 07/14/2016 9:55 PM
I have a six cylinder in my 61 apache. ware/ how can I find out what motor came in the truck. the numbers on the motor are 54-57.so its a transplant. im woundering if it was an 8 or 6.
1961 apache
chaz71 #1173892 07/14/2016 10:03 PM
post above was edited/clarified - my questions/comments no longer needed
chaz71 #1173903 07/14/2016 11:21 PM
...I learned my lesson thanks wink
Originally Posted by 59ApacheGail
There should be a number stamped into the passenger side of the engine block above the starter. There should also be numbers stamped on your frame in front of the steering gear. There should also be a vin tag in the driver side door pillar. By 1961 the engine should have the last digits of the vin number stamped that would match with the frame rail and the door pillar tag.
From 55-2 through 1959 the letter "V" was added as a prefix to the chassis serial number to indicate the truck was supplied with a V8 engine. I don't believe later truck serial numbers identified what engine was supplied.
Also, I've never heard of any Chevrolet truck having the last four didgits of the engine serial numbers match chassis serial numbers...when did that happen???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
chaz71 #1173970 07/15/2016 10:14 AM
The only way I think you can find out if a 6 or V8 came in your truck is take the VIN to a dealership parts dept and see if they can run it for you or contact GM archives and see if they can pull a build sheet.
1959 3100 Apache Fleetside
