| | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 196 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 196 | I have a six cylinder in my 61 apache. ware/ how can I find out what motor came in the truck. the numbers on the motor are 54-57.so its a transplant. im woundering if it was an 8 or 6.
1961 apache
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | post above was edited/clarified - my questions/comments no longer needed | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | ...I learned my lesson thanks
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | There should be a number stamped into the passenger side of the engine block above the starter. There should also be numbers stamped on your frame in front of the steering gear. There should also be a vin tag in the driver side door pillar. By 1961 the engine should have the last digits of the vin number stamped that would match with the frame rail and the door pillar tag. From 55-2 through 1959 the letter "V" was added as a prefix to the chassis serial number to indicate the truck was supplied with a V8 engine. I don't believe later truck serial numbers identified what engine was supplied. Also, I've never heard of any Chevrolet truck having the last four didgits of the engine serial numbers match chassis serial numbers...when did that happen??? Mike B  | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | The only way I think you can find out if a 6 or V8 came in your truck is take the VIN to a dealership parts dept and see if they can run it for you or contact GM archives and see if they can pull a build sheet.
1959 3100 Apache Fleetside
