4 members (KEVINSKI, 2-Ton, Samantha, mk72), 93 guests, and 2 robots.
Topics128,034
Posts1,055,551
#1173660 07/13/2016 2:39 PM
Woj
Offline
I posted a thread regarding my 52 3100 Pickup regarding putting in a 283 vs a 409. Well, after much reading, and your help, I decided to go with a 283. I luckily found one locally and bought it at a steal. I plan to send it out to a very well known race performance engine builder very soon. I am not going to make a race car out of the engine but just a good looking dual quad engine with a good loping sound and driveability. Now my question regarding the rest of the driveline.
Transmission
4 spd, 5 spd, maybe 6 spd???
If a 5 spd, should it be a Tremec 5 (T5)?  If so, I need to find which ones can handle whatever the power from the engine might be.
Rear Axle
Is there a leaf spring axle that bolts right in?
I have a 2nd generation Camaro / Firebird (1970-1981) axle that you can use.  That is a leaf spring type axle.
Retired Military, Six years Army, Seventeen years Air Force
Army Security Agency High Speed Morse Code Intercepter
Rigger C-130
Master Sergeant 32nd Aerial Port Squadron
Commander American Legion
Woj #1173664 07/13/2016 2:46 PM
Crusing in the Passing Lane
If going to be hauling loads, a Tremec might not be up to it, there are other truck 5 speeds out there.
Ed
EdPruss #1173676 07/13/2016 3:33 PM
Woj
Offline
Not going to haul anything just pleasure use. Any suggestions on a good trans and rear end mix?
Rigger C-130
Woj #1173740 07/13/2016 11:25 PM
A 700R4 Automatic that you will not be sorry you put in.....
A second generation rear end from Camaro but also Nova, Monte Carlo, and even some Oldsmobile and others will do the job.
Even before my retirement I found out the older you get the more your feet/legs and even arms hate a manual shift!
