Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (46 Texaco, FAST55, Pete O), 137 guests, and 4 robots.
Topics128,283
Posts1,058,519
Members48,490
Junior Member
Junior Member
The person i bought my truck from had the entire truck painted yellow. After selling it and getting it back from a friend. The exterior is now black primer (wich i am keeping) but i need to get rid of the gawdawful yellow on the inside. what's the best way to go here?
1966 SWB
bite the bullet, strip out the inside, scuff sand it, paint it a color you like - maybe semi-original, even rattle can
Junior Member
Junior Member
It'll have to be rattle can. I'm broke as can be
1966 SWB
As far as I know, there is no cheap and quick paint fix. If you find one let me know.
Junior Member
Junior Member
I'm not looking for a pr.. nevermind
1966 SWB
But, your subject was... I need a quick and cheap paint fix for the interior... there is none, if you want it done properly. If you just want another color, get a spray can and for for it.
Junior Member
Junior Member
Yep, just another color. Just dont want it to be yellow. I'm not sure how hard it would be with a rattle can pointing up at the roof either
1966 SWB
no harder than a spray gun, just make sure you wear a mask and start up there w/ the full can and work yer way down - could always do it w/ a brush on a hot day! grin
Junior Member
Junior Member
haha.. that would be fun! thanks guys. guess i'll just grab some paper and a non threatening color and get busy!
1966 SWB
You can rattle can the entire interior and end up with a decent looking job. The only problem you'll have is that it scratches easily so you have to be careful. Otherwise it's pretty cheap. Did mine with just a couple of cans... two-tone even.
Larry Bear
55.5 Chevy 3100 Panel
I did rattle can on the inside of the back of my cab, and it looked great, until I went to put in my new fiberglass headliner...scratched the heck out of the paint,..gonna use some steel wool, and try it again..It'll work, just don't touch it
Autozone carries a spray in bedliner in a can. It runs about $7 or $8 a can. It has a flat black finish. It is thick and will cover any blemishes. You will have know problem with covering any color. If you use spray paint you will have to use several coats.
Making chicken salad out of chicken sh!t.
1955 Ford F100
1954 GMC
Junior Member
Junior Member
Good idea. But how hard will it be to remove if/when i do paint the truck?
1966 SWB
Oh god jus' spray can it, then buy a can or 2 of clear coat/lacquer to keep it from actually scratchin' tha paint, & coat it kinda thick
Junior Member
Junior Member
lol.. i was just curious :p
1966 SWB
If you want something that glosses up pretty good, is RELLY tough, and with a little unique texture to it, try one of the hammer-tone rattle can finishes. Mine turned out good.
Hey Kevin, Got any pictures of that hammer finish? Thanks
Junior Member
Junior Member
Yea, i've been trying to find some too. Most i see looks kinda like that "fleckstone" stuff.
1966 SWB
Plasti-Kote makes a good hammer tone, if anyone around you carries that line, and it makes for a nice interior, especially w/ some gray \'accents\' - make sure you read the label tho - it comes in a number of colors, but the cap on all on them is gray!!
that spray can paint that you can buy at a farm implement store is pretty tuff stuff - kind of limited to colors but doesn't scratch as easy as the walmart variety. add a little clear coat and you have it made.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
use a roller with wait rolers cost money use your hand dip it in whatever old paint is lying around in the shed,nieghbors garbage,whatever you can find that is free and let rip!
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
