Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (klhansen, Hotrod Lincoln), 87 guests, and 5 robots.
Topics128,281
Posts1,058,467
Members48,490
#1173007 07/08/2016 4:02 AM
After a year of deliberation on what if any aftermarket wheels I would use on my 1 ton SRW flatbed, finaly I think I am getting close to a solution. I went out on a limb and ordered a single black rock 17"X 8" wheel from Jegs
http://www.jegs.com/i/Black-Rock/262/997788035/10002/-1
Size: 17'' x 8''
Bolt Circle: 8 x 6.5''
Rear Spacing: 3-1/2''
Offset: -25mm
So, they mount up and have decent clearance from the tie rod, about an inch +/- (i have not measured yet). Next I will pick up an old tire and get it mounted so I can see how it will sit with weight on the tire and what kind of issues if any I might have in the wheel well area from the wider tire.
http://i1062.photobucket.com/albums...B-4E71-B2A6-30EFCA0E2256_zps7qkdphay.jpg
http://i1062.photobucket.com/albums...E-4C25-98E5-15A87E8538C8_zpsb3sltenm.jpg
http://i1062.photobucket.com/albums...A-40F0-AE1F-EE231951E2B7_zpsbntvuvzr.jpg
http://i1062.photobucket.com/albums...A-44FF-B79C-A04EF625D5B0_zpsaawc8l9b.jpg
As a little sportier option to the 17" split rims or trailer wheels. What are your thought? Can you think of any issues I might be missing?
Next question, what size tire should I run on it?
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
I think original wheels are close to 5" wide? And are quite close to tie rod.
So these wheels might be about 4" more hanging out than stock on each side.
With too big a tire they might chew on the rear of the fender opening, particularly in a bump while turning.
•1952 Chevrolet 3800 pickup
---All pictures---
What would you think is a safer tire size, lets say maybe a 255/60/17 or maybe a 245/60/17?
Generally I'd go with a tall skinny tire, which might be neither.
Otherwise tall helps with going faster, so the 255?
Like you said borrow a used one and just see how it works out, either would work for that.
---All pictures---
For a visual reference, I have 17x8 rims and 265/70R17 tires. This gives me wide 31" tires. Haven't had any steering issues. The offset is key for the clearance.
Left front view of new wheels and tires
Right side profile
Dave Baird
1951 Chevy 3803
I like the look of those tires, rims also look to be the same. Thank you, this saves me a ton of time.
With stock manual steering did you notice any or much increased effort to turn the steering wheel when not rolling?
---All pictures---
Moderated by  Dusty53
