3 members (Wheelie, tclederman, Woodcmiami), 113 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#1173568 07/13/2016 1:52 AM
I have a 1953 Chevy truck with a 235 engine one barrel carb and it seems to be having a hard starting after it's been idling a while I'm not sure if this is vapor lock or its heat soaking but if it is any suggestion on how to make this any better ?
V
V Offline
Might be SOP. I find that my old carb equipped engines need more air than fuel to start once they're warmed up.
If you still have the stomp starter, try using your heel to open the throttle while your toe pushes the starter. Don't pump the carb, open it while it's cranking.
Good luck
Dave
Look at the post about three or four down from this one, "Rochester Model B Question" . Yours is probably related.
Ok I will try that . What is a Sop ?
possible SOP meanings
Standard (Standing) Operating Procedure?
With a warmed engine:
- Slowly push the pedal to floor and then release.
- Give just a little throttle (or, no throttle, depending on your engine).
- Turn on the ignition key and push the starter pedal.
Carburetion specialist
The Carburetor Shop
V
V Offline
Interesting, didn't know there were so many uses for SOP.
Don't recall anyone using it for anything other than standard operating procedure. Must be a military thing......
If all the above fails you can try this:
SLowly floor the pedal (as Carbkings article says to avoid squirting fuel into the carb)then while cranking slowly let up on the pedal. I've used that procedure successfully before too.
Good luck
Dave
