| | | Forums66 Topics128,110 Posts1,056,257 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | The person i bought my truck from had the entire truck painted yellow. After selling it and getting it back from a friend. The exterior is now black primer (wich i am keeping) but i need to get rid of the gawdawful yellow on the inside. what's the best way to go here?
1966 SWB
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | bite the bullet, strip out the inside, scuff sand it, paint it a color you like - maybe semi-original, even rattle can
Bill | | | | | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | It'll have to be rattle can. I'm broke as can be
1966 SWB
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | As far as I know, there is no cheap and quick paint fix. If you find one let me know. | | | | | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | I'm not looking for a pr.. nevermind
1966 SWB
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | But, your subject was... I need a quick and cheap paint fix for the interior... there is none, if you want it done properly. If you just want another color, get a spray can and for for it. | | | | | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | Yep, just another color. Just dont want it to be yellow. I'm not sure how hard it would be with a rattle can pointing up at the roof either
1966 SWB
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no harder than a spray gun, just make sure you wear a mask and start up there w/ the full can and work yer way down - could always do it w/ a brush on a hot day! Bill | | | | | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | haha.. that would be fun! thanks guys. guess i'll just grab some paper and a non threatening color and get busy!
1966 SWB
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | You can rattle can the entire interior and end up with a decent looking job. The only problem you'll have is that it scratches easily so you have to be careful. Otherwise it's pretty cheap. Did mine with just a couple of cans... two-tone even. | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I did rattle can on the inside of the back of my cab, and it looked great, until I went to put in my new fiberglass headliner...scratched the heck out of the paint,..gonna use some steel wool, and try it again..It'll work, just don't touch it | | | | | Joined: Jun 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 23 | Autozone carries a spray in bedliner in a can. It runs about $7 or $8 a can. It has a flat black finish. It is thick and will cover any blemishes. You will have know problem with covering any color. If you use spray paint you will have to use several coats.
Making chicken salad out of chicken sh!t. 1955 Ford F100 1954 GMC
| | | | | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | Good idea. But how hard will it be to remove if/when i do paint the truck?
1966 SWB
| | | | | Joined: Jun 2005 Posts: 68 Member | | Member Joined: Jun 2005 Posts: 68 | Oh god jus' spray can it, then buy a can or 2 of clear coat/lacquer to keep it from actually scratchin' tha paint, & coat it kinda thick | | | | | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | lol.. i was just curious :p
1966 SWB
| | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | If you want something that glosses up pretty good, is RELLY tough, and with a little unique texture to it, try one of the hammer-tone rattle can finishes. Mine turned out good. | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Hey Kevin, Got any pictures of that hammer finish? Thanks | | | | | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | Yea, i've been trying to find some too. Most i see looks kinda like that "fleckstone" stuff.
1966 SWB
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Plasti-Kote makes a good hammer tone, if anyone around you carries that line, and it makes for a nice interior, especially w/ some gray \'accents\' - make sure you read the label tho - it comes in a number of colors, but the cap on all on them is gray!! Bill | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | that spray can paint that you can buy at a farm implement store is pretty tuff stuff - kind of limited to colors but doesn't scratch as easy as the walmart variety. add a little clear coat and you have it made.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | use a roller with wait rolers cost money use your hand dip it in whatever old paint is lying around in the shed,nieghbors garbage,whatever you can find that is free and let rip! | | |
