| | | Forums66 Topics128,056 Posts1,055,798 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 4 Junior Member | | Junior Member Joined: Jul 2005 Posts: 4 | I am beginning to do some body work on my 58 apache. I was just wondering what steps should be taken to assure that my work will stick around. Should all the paint be taken off to bare metal before priming? How many coats of primer? Should the primer be sanded between coats? Any comments suggestions would be greatly appreciated.
Thanks, Curtis
1958 Big Window 3100 in the family since new.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Curtis - MartinSr is the 'pro' here on body and paint - you might take a look thru his "Basics" series before you dive in, especially the paint sections - collected here for our enlightenment Bill | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | You do NOT have sand to bare metal. That paint has been on that truck for 47 years!! It's not coming off. If you need to apply bondo, then YES sand to bare metal and use 40 grit so that the filler gets a good grip.
delete my account and pictures
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Sand the primer between coats. How much primer depends on how uneven is your panel. Primer can be used to build up uneven surfaces. Sanding the primer with a block sander smoothes the panel. Otherwise just use enough primer to cover the bare metal.
| | | | | Joined: Jun 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 23 | Take it down to the bare metal, then you know what you have to work with. Anything can be hidden under paint.
Making chicken salad out of chicken sh!t. 1955 Ford F100 1954 GMC
