0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#1173141 07/09/2016 6:00 PM
Looks great. Especially the Pats logo! Put a a big bed on it and it will a make a fine tailgate machine.
NHluvstruck...
1951 3100 5-window
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
I like it Chris. I think a tag on the front which says "little Giant" would really go well with it. smile
Thanks for the pics.
EDIT: I also meant to tell you what a good job your doing. Nice work.
Big Bolt Forum Moderator
that is looking great! What rear are you putting in it?Also, what brakes on the front? Are you changing out the master cylinder and Hydravac as well?
Mike
Hi
I just added/uploaded the hydroboost pics.
I installed it near where the hydrovac was. I have it sitting on the frame rail. I wanted to use the original pedals.
I followed Griggs advice and got the front hubs/ disk brakes from a chevy 3500/p30 , mid 90's
We used the original axle from the coe. See Grigg's sticky(Disc brakes for 3/4, 1, 1.5, and 2 ton trucks) on this forum.
I got the rear axle from a roach coach. It is from a chevy 3500. I had to use the original spring seats from my axle and weld them on to the new axle as the modern leafs are wider.
At this point, I have to run brake lines, and the pump for the hydroboost. Then I can start on the body.
I am undecided to leave the original patina or paint it
Well see.
Chris
Wow !,You were very creative with the manifold and carburetor setup.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Yea, spanky, I hope it works! I haven tried it yet.
Chris
Very nice Chris. Keep up the good work and take lots of pictures, it will help me get mine back together
Greg
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
Crusing in the Passing Lane
Perhaps a heat shield between the exhaust and the carb will be required.
Ed
Absolutely, I do plan on a heat shield, Im glad you reminded me.
I did forget.
Can you recommend a material?
Chris
Thin steel, Al would probably not last due to vibration.
Ed
