| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | When moving from Huck to Bendix front brakes on 1950 3100 is it necessary to drill out the stud holes on the drums? I'm using the original 1950 hubs with 1953 back plates and new 1953 drums from Autozone.
Jackie | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 50 should be the same 6 stud pattern as 53, are you saying the 50 and 53 studs are different sizes or have you gotten 5 stud car drums??
Bill | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | The bolt pattern is the same, its the diameter of the splines on the studs that is the issue. The splines measure @ 9/16 inch the drum holes are for 7/16. I can't imagine that can be pressed in without enlarging the holes.
Jackie | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the splines hold the stud tight in the hub, the splined portion of the stud shouldn't protrude beyond the hub flange, only the threaded part goes thru the drums, maybe you need different studs
Bill | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I'm working on the front brakes where the studs go through the drum on the inside and then through the hub.
Jackie | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sorry, wasn't thinking about the Huck setup .... the entire design of Bendix is different, I think you need to source some later Bendix hubs, which mount to the spindle before the drum, not sure about what will match your spindle, someone who's done it should speak up
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Not sure I understand problem correctly.....but the studs are bigger and goes through the hub then the drum. According to your measurements there is an eighth of an inch difference which seems to be quite a bit of difference. The studs are bigger where they go into the hub but the threaded part should be smaller...and in my experience the drums holes are just a "tat" bigger than the threads. Perhaps the place you bought the stuff needs to recheck the part numbers??
...surely someone who has worked on this recently will chime in. | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | My 1950 hubs were mounted on the outside of the drum with the studs going through a ring inside the drum then through the drum and finally through the hub. Hub and drum came off as an assembly. Does the hub go on the inside of the drum on 1951 -1959?
Jackie | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Jackie, I have a 52 3100 panel. To help understand it better I can put the hub on the spindle and then put on the drum. My hubs have three little "pins" that will fit in three small holes in the drum when you put the drum on and twist it to line up studs. Edit: maybe this will help. http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0306.htmlWhen reading the manual be sure to always make sure its talking about your truck as in 1/2 ton 3/4ton an so on. If you do not have a service manual I'd suggest book marking the Online Service Manuals for future reference.
| | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Here's a picture of a setup similar to mine. Drum | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I was trying to assemble the Bendix hubs and drums like the original Huck brakes with the hub outside the drum. The Huck drum and hub are like an assembly with the studs holding them together. The Bendix hub goes on the spindle first and then the drum goes on. I installed the studs in the hub the the hub on the spindle then the drum, everything seems to line up and fit properly! I do tend to over complicate things at times. Thanks Achipmunk and Flxible for the insight.
Jackie | | |
