1 members (crenwelge),
151
Mod | | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think original wheels are close to 5" wide? And are quite close to tie rod. So these wheels might be about 4" more hanging out than stock on each side. With too big a tire they might chew on the rear of the fender opening, particularly in a bump while turning.
| | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | What would you think is a safer tire size, lets say maybe a 255/60/17 or maybe a 245/60/17? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Generally I'd go with a tall skinny tire, which might be neither. Otherwise tall helps with going faster, so the 255?
Like you said borrow a used one and just see how it works out, either would work for that. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | For a visual reference, I have 17x8 rims and 265/70R17 tires. This gives me wide 31" tires. Haven't had any steering issues. The offset is key for the clearance. Left front view of new wheels and tires Right side profile
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | I like the look of those tires, rims also look to be the same. Thank you, this saves me a ton of time. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | With stock manual steering did you notice any or much increased effort to turn the steering wheel when not rolling? | | |
