5 members (55shaker, Shade Baby, greenie-reddy, Gdads51, Pre '68 Dave), 71 guests, and 0 robots.
Topics128,035
Posts1,055,570
#1172880 07/07/2016 10:09 AM
I have just saved a couple of 216 engines from the scrap man.
I can identify one as a '42 - '53 by the 839770 block casting number and I am happy with that.
The other has me confused. It has the short side plate + 2 studs valve cover. Block # 5843350 . I cannot find this number listed , any ideas anyone ?
Head # on this engine is 3835913 engine is painted green (a long time ago) has a 6v gen and starter.
Congratulations, your 216 is a 235.
Apparently the block is a 1953 - 235, and the head is a 1954 - 235.
http://hotrod.gregwapling.com/chev-trucks-47-55/canadian-chev.html
http://1954advance-design.com/Stovebolt-engine/casting-numbers.html
Thankyou very much Stove , a 235 eh, I'm very happy about that smile
Dusty #1172963 07/07/2016 10:52 PM
I just pulled the valve cover (2 stud) off and find the gasket and head have the 4 screw holes for the later 235 valve cover .
Had me fooled smile
There are a couple of tight exh valves to free up , then I will see if it goes smile
Does it have the oil distributor on the drivers side, below the manifold. If not, it will be a full pressure, insert rod bearing engine with aluminum pistons (originally came with a Powerglide transmission in cars in '53). A quick tell for this engine is the presence of captain's bars on the block above the starter. Jackpot!
Carl
P Online: Content
Carl, you must have been paying attention!
My Blog
Thanks Carl , there is no external oil distributor , no captains bars either , that I can see.
P Online: Content
From the Canadian casting number site:
1953 235 ENGINE:
ENGINE # C642,669 CYLINDER BLOCK # 5843350
ENGINE # C642,948 [1300 SERIES] Block # 3695408 Head # 3835499 [261]
ENGINE C OR T THEN # 668,082
CYLINDER HEAD # 3701887
CYLINDER BLOCK # 5843350 CAST DATE L-10-2 DECEMBER 10 1952
1953 235 BLOCK:
ENGINE # C645,068 CAST # 5843350 CAST DATE L-16-2 DECEMBER 16 1952
BELL HOUSING CAST # 3701433
1953 1304 ½ TON PICKUP
# 3131403006 ENGINE # C649,323 # 5843350 [235]
1953 ½ TON 5-WINDOW PICKUP
# 3131417937 ENGINE # C714,130 CYLINDER BLOCK # 5843350
1953 235 ENGINE:
Cylinder Head # 3701887
Cylinder Block # 5843350
1953 235 ENGINE:
Cylinder Block: # 5843350
Engine # C704,488
1953 CHEVROLET PICK-UP
3131402932
My Blog
No, not really. I just happened to luck into one when I bought my '50 3100.
BTW, his is Canadian with no oil distributor and he doesn't see captain's bars. Is it a full pressure engine?
Carl
Dusty #1173075 07/08/2016 11:38 PM
P Online: Content
No oil distributor = full pressure in my mind.
My Blog
Dusty #1173076 07/09/2016 12:37 AM
Thanks for your help guys , I just pulled the g/box off and looked inside it . A bit of hardening off 2nd gear , all the rest looks good . Huge clutch . I took the starter off and checked again for captains bars , none there .
I have had the plugs out and valve gear off and oil down the bore , so this morning I got a bar in thru the starter hole and eased the crank around a little smile smile moves ok now . I'm getting excited about this engine .
Not withstanding it was pulled for scrap , I think it has potential.
This would be the first I have ever heard of a '53 235 with full pressure without captain's bars. But the Canadian engines seem to have a lot of surprises. One that comes to mind is the Canadian 216 with short side cover.
Carl
P Online: Content
I would agree with you there!
My Blog
