2 members (baldeagle, dunfire),
50
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I have just saved a couple of 216 engines from the scrap man. I can identify one as a '42 - '53 by the 839770 block casting number and I am happy with that.
The other has me confused. It has the short side plate + 2 studs valve cover. Block # 5843350 . I cannot find this number listed , any ideas anyone ? Head # on this engine is 3835913 engine is painted green (a long time ago) has a 6v gen and starter. | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thankyou very much Stove , a 235 eh, I'm very happy about that  | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I just pulled the valve cover (2 stud) off and find the gasket and head have the 4 screw holes for the later 235 valve cover . Had me fooled  There are a couple of tight exh valves to free up , then I will see if it goes  | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Does it have the oil distributor on the drivers side, below the manifold. If not, it will be a full pressure, insert rod bearing engine with aluminum pistons (originally came with a Powerglide transmission in cars in '53). A quick tell for this engine is the presence of captain's bars on the block above the starter. Jackpot! Carl
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Carl, you must have been paying attention!
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks Carl , there is no external oil distributor , no captains bars either , that I can see. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | From the Canadian casting number site: 1953 235 ENGINE: ENGINE # C642,669 CYLINDER BLOCK # 5843350 ENGINE # C642,948 [1300 SERIES] Block # 3695408 Head # 3835499 [261] ENGINE C OR T THEN # 668,082 CYLINDER HEAD # 3701887 CYLINDER BLOCK # 5843350 CAST DATE L-10-2 DECEMBER 10 1952 1953 235 BLOCK: ENGINE # C645,068 CAST # 5843350 CAST DATE L-16-2 DECEMBER 16 1952 BELL HOUSING CAST # 3701433 1953 1304 ½ TON PICKUP # 3131403006 ENGINE # C649,323 # 5843350 [235] 1953 ½ TON 5-WINDOW PICKUP # 3131417937 ENGINE # C714,130 CYLINDER BLOCK # 5843350 1953 235 ENGINE: Cylinder Head # 3701887 Cylinder Block # 5843350 1953 235 ENGINE: Cylinder Head # 3701887 Cylinder Block: # 5843350 Engine # C704,488 1953 CHEVROLET PICK-UP 3131402932 Cylinder Head # 3701887 Cylinder Block: # 5843350
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Carl, you must have been paying attention! No, not really. I just happened to luck into one when I bought my '50 3100. BTW, his is Canadian with no oil distributor and he doesn't see captain's bars. Is it a full pressure engine? Carl
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | No oil distributor = full pressure in my mind.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks for your help guys , I just pulled the g/box off and looked inside it . A bit of hardening off 2nd gear , all the rest looks good . Huge clutch . I took the starter off and checked again for captains bars , none there . I have had the plugs out and valve gear off and oil down the bore , so this morning I got a bar in thru the starter hole and eased the crank around a little  moves ok now . I'm getting excited about this engine . Not withstanding it was pulled for scrap , I think it has potential. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | No oil distributor = full pressure in my mind. This would be the first I have ever heard of a '53 235 with full pressure without captain's bars. But the Canadian engines seem to have a lot of surprises. One that comes to mind is the Canadian 216 with short side cover. Carl
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would agree with you there!
