4 members (HelmutVonSchet, walter74, jay d, Rich'sToys), 95 guests, and 2 robots.
Topics128,049
Posts1,055,678
1950 3100 with 1951 rear end
While changing my metal jacketed park brake cables with plastic jacket type I attempted to open the clamp a bit so the larger cable would fit and promptly broke the clamp. Then I moved on to the other side and carefully tried again with the same results. I can weld the clamps back but that is not going to make the cables fit.
Any of you had this issue or am a lone bone head?
Jackie
I drilled mine to fit the larger cable.
I think the bracket maybe cast...so brazing might be a good fix.
Well welding proved unsuccessful so I placed the ferrule part of the cable 3/4's into the clamp and tightened the heck out of the broken piece. It stays put when cable is pulled by hand. I may need to fabricate brackets I can bolt to the existing one I suppose.
Jackie
