4 members (Lightholder's Dad, Jay R, Nick in Manitou, GIJOE298), 118 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
#1169763 06/16/2016 9:48 PM
So, my 1 3/4" carb actually measures 1 11/16" at the throttle plate. After sourcing a local (rebuildable) replacement, it measures the same. I guess all this stuff about a 1 3/4" throttle plate on the 261 is nonsense??? Its bigger than a 235, but not THAT big.
Or is there another carb that I should be looking for???
I think you're misreading the specifications. Isn't it the VENTURI- - - -not the throttle plate, that's supposed to measure 1 3/4 inches?
Normally a venturi will start large, shrink in size, then taper back out to a larger throttle plate. Larger. To install a smaller throttle plate would be detrimental by design. It won't draw fuel properly. Call it an assumption on my part, but it was quite a surprise to see the small throttle plate. Obviously it was intended to idle well and drivability doesn't really matter.
