| | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 48 | So, my 1 3/4" carb actually measures 1 11/16" at the throttle plate. After sourcing a local (rebuildable) replacement, it measures the same. I guess all this stuff about a 1 3/4" throttle plate on the 261 is nonsense??? Its bigger than a 235, but not THAT big. Or is there another carb that I should be looking for??? | | | | | Joined: Feb 2004 Posts: 29,858 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,858 | I think you're misreading the specifications. Isn't it the VENTURI- - - -not the throttle plate, that's supposed to measure 1 3/4 inches? Jerry
| | | | | Joined: Jul 2014 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 48 | Normally a venturi will start large, shrink in size, then taper back out to a larger throttle plate. Larger. To install a smaller throttle plate would be detrimental by design. It won't draw fuel properly. Call it an assumption on my part, but it was quite a surprise to see the small throttle plate. Obviously it was intended to idle well and drivability doesn't really matter. | | |
