1 members (Phak1),
100
Mod | | | Forums66 Topics128,195 Posts1,057,375 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | Hiya folks.
I was toying around today with my dad's old '53 3100 yesterday... and the steel brake that goes to the rear axle burst.
egads!
Luckily I was stopped when it happened... 5 minutes earlier and it would have been an interesting ride with the park brake.
Time to swap out the metal lines then... I've swapped out and bent straight ones from the store before, but I noticed some of the vendors have all the pieces in a kit, but I imagine unless specifically written, they are all straight lines that need to be bent as well.
Anyway, just looking for suggestions for steel brake line sourcing, pros and cons.
Thanks.
-W | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | got mine from inline tube, yes they were straight and had to be bent.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Inline tube as well, but ordered mine stainless pre bent. Exact as originals and fit perfect. Kevin
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Inline tube as well, but ordered mine stainless pre bent. Exact as originals and fit perfect. I realize you are asking about steel lines but wanted to add info about the stainless lines in case you consider them. I went the same route as above, pre-bent stainless. Looks very nice but if I did it again I would go with steel. The fittings on the stainless were very hard to seal. Had to repeatedly loosen and tighten them but after doing that 2-3 times they are now fine. There may be a different bevel on the stainless fittins. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | The stainless steel lines are not as soft as steel lines, requiring the progressive form-fitting of multiple tightening-loosening-tightening routine mentioned by Chuck above. After you do this to one or two fittings, you will get a feel for it and it is easy to do. BTW, I do this same procedure with steel lines to make sure that I don't have any leaks. The pre-bent stainless lines from Inline are as close to exact fit as you can get, and you will never have to worry about your brake lines ever again. Carl
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just put all new lines on my 38 Master. I used the new copper nickel lines and I found them much better to work with. I bought lengths and cut most to size so I flared at least one end on each. I don't think they can rust so are my choice for sure. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I just used the copper nickel lines and they worked out nice. Jeffrey | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | Thanks a bunch for the replies folks.
-W | | |
