8 members (Stewart2, RdsLessTaken, 55shaker, Steelonsteel, Otto Skorzeny, Wayne67vert, cmayna, klhansen),
115
Mod | | | Forums66 Topics128,165 Posts1,057,010 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Tried to bleed the rear brakes on Big Red this weekend. The blender screw on the left wheel did not look like the normal screw. It did not have a arrow tip like the other ones. When I tried to to loosen it it would not budge. I tried vise grips but no luck. I my small mind I thought "Hey I will take off the the rear wheels and remove the drum, when that is done I can remove the backing plate and go to town on that pesky little nub" well I got all the bots off the backing plate but could not for the life of me figure out how ro get it off? I'm sure this is a routine procedure. Coul you please enlighten me.
Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | If you got that far, it is not too tough to remove the wheel cylinder. The backing plate does not need to be removed. The brake line will need to be removed. With the wheel cylinder out, it can be put in a vise to get the bleeder screw out. What year and model is the truck? The shop manual can help: http://chevy.oldcarmanualproject.com/ Good link and easy to use.
Steve H
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | When you have the wheel cylinder out check the condition of the bore, might be pitted enough you don't have to worry about the stuck bleeder screw and instead source a new cylinder. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Are there any interchanges for it? I'm going to assume that that is not something I'm going to find at my local NAPA?
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Gentle heat and proper line fitting wrench or Vise Grip works well.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'm not familiar with parts availability and part numbers for the older trucks but I wouldn't be surprised if they're available new. It sure wouldn't hurt to investigate. I've had good luck getting brake parts at NAPA for things I didn't really expect them to have but they still did.. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I looked on Napa online and only saw a rebuild kit for the master cylinder. A good brake and clutch supply place should be able to get them or at least get you a part #. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Alas too far gone. Got the cylinder off, tried to remove the bleeder valve and it snapped off. Tried to use my trusty(not so much anymore) nut puller( no its not the name but thats what I call it) and it broke it. Don't want to deal with it so going new. Thanks for the help
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | TK421, be sure to replace/rebuild them in sets. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Think I may have found them @ NAPA. Just need someone to confirm that the specs did not change between 41 and 46. Every thing I have read says that there is no difference. Just want to be xtra sure before I order
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Have a little faith. Go ahead and order them and take your old one with you when you pick them up. If wrong they CAN send them back. Happens all the time. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Very little changed between 41 and 46 trucks. I would suggest that you ask for 46 parts as that year seems to show up in the books/databases more so than 41-45. | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | It's a little late now, but the next time you need to free up a stuck bleeder screw, here's a procedure that works:
Remove the wheel cylinder and remove all the rubber parts, pistons, springs, etc. It needs to be a bare casting with nothing but the cast iron cylinder and the bleeder screw. Clamp the cylinder in a vise, and heat the bleeder screw with a torch until it's red hot. GENTLY move the bleeder back and forth with a 6-point box end wrench or a socket. If it gets hard to move, stop, and heat again. It might be necessary to let the casting cool down, apply some penetrating oil like KROIL or PB Blaster, and heat again. I've salvaged lots of brake cylinders that way. Jerry
| | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Thanks for all the advice. It is greatly appreciated.
| | | | | Joined: Apr 2016 Posts: 1,052 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,052 | I did the brakes on world war 2 duck. could not find the wheel cylinder anywhere. Even the people that restore those could not help me. went to napa to see if they could make one and they said they had 3 in stock. Guess I overthought that one.
| | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | They have them @ NAPA!!!! Thanks again folks. I may even be able to get her running for the weekend
