2 members (Gdads51, WICruiser),
83
Mod | | | Forums66 Topics128,143 Posts1,056,495 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I have the 1947-1954 Truck Factory Assembly Manual. Some of the drawings give specific models, such as "Models 3100 - 3600 - 3800 - etc" but other drawings say "Models - All RD."
What's RD stand for? Thanks!!
Also is there an index somewhere so you don't have to go through every page, one by one, to find the drawing you're looking for? Thanks, again. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | RD means right hand drive as these were used and I believe built in Australia. Someone on this sight made up an index perhaps they will chime in. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Ah, yes. I was focused on the gas pedal but I see the drawing includes a cross-over rod to get the action to the left side of the engine from the right side pedal. Thanks. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I made a small rudimentary index a few years ago but, it was for my own project and only references dwgs for a '51 3100. If it is of interest let me know and I will dig it up.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... I put topic headings for my panel inside of the back page. I also put some "tabs" on the pages I referred to a good bit. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I found a copy on my Photobucket page (see below). If you want a copy PM me a I can send you a copy of spreadsheet so you can mark it up as you wish.
Mostly, I used ton of post-it tabs as Alvin suggests above. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I found a copy on my Photobucket page (see below). If you want a copy PM me an I can send you a copy of spreadsheet so you can mark it up as you wish.
Mostly, I used ton of post-it tabs as Alvin suggests above. In which Photobucket album? Please mail me a copy (address is in my Profile) and I will host-it/post-it so stovebolt-members can view it without popups and ads. Thanks, | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
