2 members (TooMany2count, Rich'sToys), 68 guests, and 7 robots.
Topics128,021
Posts1,055,353
Members48,420
#1165198 05/13/2016 10:49 PM
What is the cap. of the steering gear box I first put in gear oil and it leaked, so I am putting in corn head grease. Would like to know how much it holds. 53 3100 standard 53 steering box. root
root #1165289 05/14/2016 2:05 PM
Fix the leak ???????
root #1165290 05/14/2016 2:12 PM
https://www.flickr.com/photos/advance-design_parts_co/sets/72157632210242370/
Here is manual, it shows where the level is but not how much. My '46 steering box will hold a whole tube of grease.
root #1165291 05/14/2016 2:13 PM
The leak could be a housing gasket or could simply be caused by the use of gear oil vs the specified self-levelling grease. There is no bottom seal.
Root - when you check with Tractor Supply for the corn head grease, see if they have NLGI 00 cotton picker spindle grease. It is the original specification self-levelling grease for the steering box.
root #1165498 05/15/2016 10:44 PM
Well, I just put in about a tube and 3/4 of corn head grease in gear box. Took out the bottom bolt and pumped in the grease till it came out the fill port. After driving it for a while I will check the grease level again. The JD dealer I went to did not have NLGI 00 grease. Thanks for the help. root
root #1165505 05/15/2016 11:24 PM
Thanks for the report, root.
Now we know what to advise people when they empty/fill a steering box (two tubes).
root #1165512 05/15/2016 11:52 PM
Gas Pumper
Gas Pumper
I haven't found any cotton pickin NGLI 00 around here yet. Still looking. You would think in the heartland a few blocks away from Hesston Corporation you could find it easy.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
root #1165515 05/15/2016 11:56 PM
We can't easily get the NLGI 0 around here, but I hope it is available in NC farmland.
root #1165517 05/16/2016 12:11 AM
Here is an interesting read, seems tractor guys are have the same problems as truck guys. http://www.tractorbynet.com/forums/oil-fuel-lubricants/213399-0-00-grease-sources.html
root #1165797 05/17/2016 8:55 PM
Back in the day, I betcha most pickup owners also owned tractors. Today it's probably not one or two percent. Interesting to think about. Real stats on such things probably don't exist.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
root #1165800 05/17/2016 9:33 PM
I have used 90w gear lube in the past with few issues.
I resealed the box and reassembled the box.
On this current project I just add a grease/STP/gear lube mix that just flows like cake batter at 70*.
This mix is slick as snot on your hands and is just barely pourable into the top fill port. Certainly good enough especially considering what was in there for the last 50 years.
Skooter #1165820 05/18/2016 1:08 AM
You are probably right. However I'll bet that most tractor owners have a pickup.
Skooter #1165874 05/18/2016 11:02 AM
Some still have tractors...couldn't have lifted all of the heavy truck parts on my restoration without one.
Lots more pictures
