1 members (NJC),
77
Mod | | | Forums66 Topics128,283 Posts1,058,506 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Jacked the Panel up and put a new seal on the automatic tranny shifter arm and replaced a bad headlight switch. The NEW front drums have always been a suspect for being out of round so I pulled them off tonight and will get them turned in the morning. Replace the end on a battery cable and it also got a good lube job.
If the weather is decent I may drive it to Family Reunion in Ga. Sunday and drop by and see some of the guys at the Canton car show.....unless the little short lady "insist" on the Buick...but hey she rode in it to K.C. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | put the amps, crossover, and sub back in my Suburban tonight since I listed them in the for sale ad! | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yesterday, I welded up the spring hangers and machined them to the correct size . This morning I finished assembling the rear and drove to the Kustoms breakfast, it is the 6th anniversary and about 450 cars etc showed up . Perfect weather , great day. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I put an adjustable main jet in the Suburban carburetor and checked the timing. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need to replace the rest of those brake lines. | | | | | Joined: Dec 2014 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 66 | Reinstalled the ring and pinion assembly after having the old pitted parts replaced. Also with new bearings and gaskets. Wow-talk about quieter! One of the best things I've ever done.
'59 Apache ‘21 Beta 390RS ‘18 BMW R1200RT '12 Ford Flex '13 Aprilia Tuono ‘11 Ducati Hypermotard Salisbury, MD
| | | | | Joined: Aug 2014 Posts: 15 New Guy | | New Guy Joined: Aug 2014 Posts: 15 | You need to replace the rest of those brake lines. It's on the list although the brake lines are not that bad at all. The cracked line was from where someone had crushed it somehow. | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | You wont see the bad spots, both steel and rubber lines fail from the inside out... Mike B  | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Project fender bender got the rest of the front clip buttoned up. I fitted/wrestled the grill, bumper mounts,splash apron and bumper into place. All going well I should be rolling again this week! A shade over 4 months of Stovebolt driving abstinence is not good for the soul..... 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | Cleaned up the loose rust and treated the back half of the frame (bed is off) with a rust convertor. I also replaced the shocks while I had easy access and replaced the rubber brake line at the back axel. I am so close to starting my bed build. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Cleaned up the loose rust and treated the back half of the frame (bed is off) with a rust convertor. I also replaced the shocks while I had easy access and replaced the rubber brake line at the back axel. I am so close to starting my bed build. Looking at your tag line you're well on the way,keep up the good work. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | today, I charged the battery and fired up my 65 suburban. I then drove it out of the weeds and into my yard to assess what it needs to be on the road again. It needed brakes and carb when i quit driving it in 1992.
I bought the truck valentines day 1969 w/22,000 miles on it. I'm the second owner. For twenty-five years it was the only vehicle i owned, it was my work truck, grocery getter, RV,stump puller etc. I even lived in it for awhile.
when i was younger i put up with manual brakes and manual steering and clutch. I think now at the age of 67 i might consider power steering ,power disc brakes and auto trans.
I'm off to dig up my shop manuals that have been packed away, i hope to be back with word that another old burb is on the road. Jerry.
i love my dog's 1965 suburban.
| | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | I got the plates on it and drove it the 10 miles home. Its now out front of our Firehall for a fundraiser dinner for the evening! | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I rebuilt the master cylinder. The steel lines were rusted solid to the connector nut. The only way to get them loose was to cut the lines. Now I am planning a trip to the parts store for some new steel brake lines. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Tried to fit the last piece in the jigsaw that is/was "Project fender bender" last night and conceded defeat.
The right rear fender.
I was trying to tighten the fender bolts and I realised even at 6'4" my arms just aren't quite long enough to reach inside the bed whilst tightening the nuts underneath and fit the fender seal at the same time. My able assistant a.k.a. "Da Boss" has been pressed into action and will provide much needed help this morning,then it's road test time. I still need to address a little header leak then it's all systems GO! (I hope)
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 6'4 you say? Well John, did you ever play Point Guard? LOL
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | 6'4 you say? Well John, did you ever play Point Guard? LOL No Jim,I did dabble in basketball in school but it never really floated my boat. Swimming and Ice Hockey were my sports of choice.  Back on topic now,I(we) got 'er done yesterday. Just some leaky headers to attend to,that's todays task.
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I added some more shims on the torque tube ball, might stop leaking... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1953 panel,
Adding shims will most likely loosen the "joint"? That might result in increased leaking?
| | | | | Joined: May 2015 Posts: 11,278 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,278 | Not today, but Saturday, I got another patch welded onto my LR fender. Probably 1/000 of the total number of tasks.  How do you eat an elephant? One bite at a time. I'm nibbling away at it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | I put the current license tag on and put the insurance card in the glovebox. Then I got out the rubbing compound and did the whole truck, it had black mold spots and small scaly lichen type things all over, it sure looks better, wax tomorrow!
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | today, I charged the battery and fired up my 65 suburban. I then drove it out of the weeds and into my yard to assess what it needs to be on the road again. It needed brakes and carb when i quit driving it in 1992.
I'm off to dig up my shop manuals that have been packed away, i hope to be back with word that another old burb is on the road. Jerry. A truly inspiring story.
| | | | | Joined: Apr 2016 Posts: 96 Shop Shark | | Shop Shark Joined: Apr 2016 Posts: 96 | After about a month of waiting my truck was finally delivered! I've now confirmed that i have a 1954 GMC 350-27. I have a lot of work ahead of me, and can't wait to get it running!
1954 GMC 350-27
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Congrats! What's a 350-27? Brad Wrench Fetcher, PhD | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I changed out the ignition parts, changed the oil and filter, lubed over 20 fittings. | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Congrats! What's a 350-27? Brad A 350 is a 2 ton GMC. I think a 27 is a 270 engine. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1953 panel is correct:
350 indicates 2-ton 35x-27 = 270 engine 35x-24 = 248 engine
351 = 2 ton with 137" wheelbase 352 = 2 ton with 149" wheelbase 353 = 2 ton with 161" wheelbase 354 = 2 ton with 179" wheelbase 355 = 2 ton with 199" wheelbase
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Super cool trucks, AdamK! Thanks for explaining, Tim & 53panel; initially, I thought it was a 'rod engine.
Brad Wrench Fetcher, PhD | | | | | Joined: Dec 2012 Posts: 122 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 122 | Went over the whole truck's existing paint with rubbing compound, then with polishing compound, then with wax then buffed it off. Of course, it didn't fix any dents or scratches, but it sure looks a heckuva lot better! It sparkles in the sunlight instead of just absorbing the light like flat-finished paint.
Registered to show in a local town sponsored car show on May 21st. It will be my furthest excursion from the house!!
| | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | After reading such great progress being made on some very cool trucks, I hesitate to say this ... but I just listed one of my trucks for sale. Oh well, it's time to narrow down my projects to a semi-manageable amount.
I then went and sat on the bed of the '37 truck (the one I'm keeping), dreamed a bit of possibly starting it up and driving it in the town parade some year. It was a beautiful day, sunny and bright. A good day to dream of what can someday be.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Given up trying to seal the cheap generic block hugger headers on my '50,the mounting flanges are simply too thin and as a consequence have warped. I've since scored a set of good ole cast iron ramshorns from a friend and ordered yet another pair of gaskets. As an added bonus it looks like i'll have gained some extra steering clearance too. I also fully lubed all the new ball joints and steering rod ends too. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2012 Posts: 122 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 122 | It was a beautiful day, sunny and bright. A good day to dream of what can someday be. Your post resonates,Husker... but I'm working hard to get my dream-do ratio down!! | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | Your post resonates,Husker... but I'm working hard to get my dream-do ratio down!! Thanks, and I am glad to hear you are turning that ratio around. Keep at it! | | | | | Joined: Jul 2014 Posts: 363 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 363 | After reading such great progress being made on some very cool trucks, I hesitate to say this ... but I just listed one of my trucks for sale. ... Most of ours started with someone else making that decision. Gives the next person the opportunity to sit and dream too. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | After reading such great progress being made on some very cool trucks, I hesitate to say this ... but I just listed one of my trucks for sale. Oh well, it's time to narrow down my projects to a semi-manageable amount. I hear ya, I just sold my 59 Suburban and trailer today. | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | Most of ours started with someone else making that decision. Gives the next person the opportunity to sit and dream too. Thank you. That is a comforting thought. Cuda, hope your 'burb went to a good home. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Cuda, hope your 'burb went to a good home. Thanks, I think it did! Hopefully he will join here! He used to have a 63 chevy truck and said his dad is a mechanic at an International truck dealer. Talking with him, I got a pretty good feeling! | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | That's good.  The benefit of selling now, for me, is that scrap prices are so low that I don't worry that is where it will end up. ha! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | OK,y'all can quit posting about what you didn't do. | | |
