1 members (Rusty Rod),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,638 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | howdy ya'll, what do yall thank bout puttin implement paint on a 53? IS it ok? Right know im just doin a quick restore and then in the future a frame up. Thanks alot
If ain't broke Break it and fix it.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Well, it is OK, as in better than primer for protection and will probably look fine from 6 feet away. It's YOUR truck. The good thing about AD's is that they are curvy enough to look fine with just about any kind of paint.
If it really bothers you, just buy a little paint and do a fender or the tailgate to see if you like it.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | Thanks alot 4onthefloor! But i have yet a nuther question for ya. Would you recomend using primer and or hardner?(with implement paint)
Thanks again Slade
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I guess I've had a shelter life, but I gotta ask. What is implement paint? Cecil......... | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | if you spray the paint it will be as good as the enamels they had in the 50s and i would prime it unless your on a real budget | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | implement paint for tractors loaders machinery | | | | | Joined: Jun 2005 Posts: 35 Member | | Member Joined: Jun 2005 Posts: 35 | Be careful when considering adding a hardener to paint you intend to remove at a later date unless you know exactly what you'll have to do to take it off.
I was doing some body work on a (deleted) one time and ran into paint that literally defied a sandblaster. Finally had to use aircraft paint stripper - and it took three applications to remove the paint! | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I did a Trooper years ago with tractor paint from Central Farm and Tractor that went out of business. 20 bucks with hardener. Trooper looked great paintwise. Could have use a little help on bodywork............
Dan | | | | | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | thanks everbody I got my paint from crow-burlingame today and im figuring on puttin it on this coming week if not tommorow. I'll get back a hold of everbody and tell you how it came out. Should i use a brush,roller or both i dont have enough money to spend on getting it sprayed like i would want to. also does anybody know any tips for getting rusty clutch head screws out. i bought a kit of 4 from chevy duty but them darn thangs just won't break loose. thanks
| | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Blue, I'd use a roller if possible. Your local hardware store will have small 3-4" trim rollers that should work on the tighter areas. Brushes, except the really expensive camel hair ones, will likely leave ridges and brush marks in your paint.
The only thing I've found for getting out the rusty screws is patience and LOTS of WD40 (or a drill - sorry).
Good luck, and take some pictures for us. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | if you brush or roller keep a fine mist spray bottle near with paint thinner if the brush starts dragging spray the surface and the brush try to do it in sections with one coat coverage watch for runs the clutch heads get a 4 inch angle grinder and grind them off dosnt take long at all wear eye protection | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | impliment paint is just plain old enamel paint (like all cars and trucks were painted with back in the good old days)prep your surface prime any bare metal and start spraying.put enough paint on it so you can wet sand and buff any bad spots. | | | | | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | sorry fellers, but i didnt use a brush or rollers my cousin took it to his shop in little rock were we puit on a original taillight and back bumper primered it with primer he had and painted it with paint guns. IT LOOKS LIKE A DOLL!!!!!!!!!!IT IS BEAUTIFUL!!!!!!!!!! the paint is close to the original 1st commercial red that was on the truck new. in a little while i will be posting the pics on my gallery page under "slade kagebeins 1953 chevy truck".i love it thanks everbody
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Isn't that implement paint a two part epoxy paint?
If yer gunna paint a truck you might as well do it right. I doubt that you will save that much money using impement paint. The hard part is the body work and prep. It doesn't make sense to do a crappy, temporary paint job.
If you shoot enamel, USE HARDENER.
delete my account and pictures
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | VanSickle's tractor/implement paint is a single-part enamel. Only $20-$30 a gallon, but a friend has painted several cars (and tractors) with it, he swears by the stuff. | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | So you save a hundred bucks but the body work and prep is the most costly (time consuming) part of the paint job. If that implement paint is as good as acrylic enamel (it may be acrylic enamel, is it?) and the color you want, then I'd have no problem with it. I would not however waste all of my body work and prep with inferior paint.
| | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | you can usually get good quality impliment paint for around $30 gallon.you cant even buy the hardener for these new wonder paints for that.also impliment paint wont kill ya if you breathe a little of it. | | |
