5 members (Youngin' Tut 59, 52Carl, Bill Hanlon, UtahYork, Peggy M), 181 guests, and 0 robots.
Topics128,190
Posts1,057,339
Members48,469
#116319 04/05/2004 5:22 PM
Junior Member
Junior Member
I'm getting ready to rebuild my wing windows on my 52 chev pickup.
Can you offer any tips on how to remove and replace the glass?
Mike
#116320 04/06/2004 2:43 AM
The shop manual shows you how.
1951 1 Ton Completed
#116321 04/07/2004 4:22 AM
I did both of mine a couple of weeks ago and the following worked well:
Removal - soak the edges of the window seal in gasoline, both sides. Let it soak in for about 1 hour, then slowly pry the seal and window out starting at the top corners. Move slowly and just apply constant, but gentle pressure. Then pull the window out with your fingers ... slowly.
Installation - coat the inside of the vent frame with motor oil. I used some available 5W-30. Push the window and seal in the frame and let it set overnight. Trim the seal the next morning.
Good luck.
shoeless
