8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert), 99 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
I order them here: americanclassic.com/images/WFK39.jpg
Was concerned about the tool to smash them, then saw that these came with a rubber insert that keeps the ferule tight. I dont see it going anywhere once the handle is inserted. The metsal seemed thin, but it wont be in the rain- often anyway. Easier to install I'm saying.............
I'm not sure about your '40 but on my 37 you have to spread the ferules at the back side. I do use a rubber O-ring to help keep it tight and not scuff the paint.
EDIT: I'll correct myself. After 37 it seems you do not need the tool. Perhaps this will explain it better than me.
https://www.fillingstation.com/articles/installferrules.htm
The ones I just bought dont seem to be made to spread- the rubber insert is about .5'' THICK, WITH A LIP, AND THE CHROME FERULE PUSHES INSIDE of it snuggly. I dont see a new to try and press it- cant go anywhat with the handle on!
