6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#1161917 04/23/2016 7:35 PM
I am back working in my chevy 54 truck. after 7 years of being stopped, you can imagine how the fuel tank was.
I cleaned it this weekend. After washing and making sure no more dirt came out, I put it under the sun for hours to dry.
Now the question is should I keep it full or empty of gas if I will not start the engine in maybe couple of months?
I think I would just use a little out of a jug before
I got serious about putting the tank back on, do all the preparations for restarting after all this time not running first before you even try to get it running..
Redryder pix
My Hotrod
They sell a product you can spray into the tank to keep it from rusting while you finish you other work. Should be available at your FLAPS.
I'd put Red-Kote in it.
To answer your question directly, I would suggest filling the tank completely with ethanol-free gas. I bought my current 1950 3100 with 12 gallons of 15-20 year old gas in the tank. I drained the tank and poured the orange-colored gas into a work truck (not mine)and drove it 120 miles to get rid of it. There was very little sediment in the tank, nor rust on the side of the tank. I am assuming that the old gas was ethanol-free, given the age and that ethanol didn't come to Virginia until 2006.
Carl
Crusing in the Passing Lane
I have used old gas, non-alcohol, and ended up bending pushrods when the valves seized due to varnish from old fuel, others have had same issues-don't waste energy on old fuel, not worth it.
Ed
Ed
You bring up a good point, Ed. I would not have used that ancient gas in any of my vehicles. I used up that gas in a truck which was literally on its way to the bone yard.
Carl
I never bent any push rods, but I gummed up the valves pretty good on my F-350 when I first got it running. Ended up replacing the tank. Fortunately I was able to find a used one that was nice and clean.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I wouldn't trust just putting it under the sun to dry. I recommend purging the tank with a fan blowing into it.
1959 3100 Apache Fleetside
Put a little outboard oil in with the gas and swish it around to get some oil in the. Cracks. The oil wont hurt the engine might smoke a bit. Will keep the tank from starting to rust inside especially after a rince. The outboard oil is made to. Burnt by the outboard anyway.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
