| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Hey all,
As with some of the other posts that i've read, I'm considering doing a bit of a fix and drive, instead of starting to tear her down. I would like to experience the 'stock' drive to see if I really want to make any upgrades. One of the things to consider is the requirements of the Ontario gov't. I was wondering if anyone had any documentation as far as a previous safety or safety check experience that they'd like to share? I'm assuming I will need to over-haul the brakes and ensure the lights are functional, but will I need to add more tail lights? Some kind of a rear_wheel cover? (just cab and frame) What about a cracked windshield?
This is my first antique vehicle, so i'm not clear on what can stay original and what needs to be upgraded.
Thanks! | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Hey Goach, Ontario is revamping the entire safety check requirements, supposed to kick in on July 1. Up til now, you don't need to add lights that were not installed by the manufacturer. Not seatbelts either or signal lights. I am not up on the proposed changes, you'll need to check it out. edit, cracked windshields will not pass.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Some things will depend on the mechanic that does your check. I think you will need some kind of fender or shield over the back wheels if you don't have that. It used to be that you didn't need a functioning speedometer which is kind of interesting. As Leo said, they are revamping the standards but hopefully the changes will be more for the more modern vehicles. One thing that is complicated is building a truck with a modified engine etc., especially with a substantially modernized upgrade. | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Here's a link to the government's summary of changes: http://www.mto.gov.on.ca/english/trucks/motor-vehicle-inspection-stations.shtml#passenger That site includes a link to the Ontario government's full regulations as a PDF file. Much discussion at my local car club over how all of this might affect modified street rods, rat rods etc. It's still not clear, but much of the suspension and height rules seem aimed at guys who jack up their 4 x 4's for mudding, etc. Cheers, John | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Thanks Waves, I'm aiming to get my bolt inspected before July 1st! Hopefully I can find everything I need to get'er done. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | As per the previous comments I think it has a lot to do who will be doing the inspection and whether you are city or country mouse. I did the same thing when I got my truck and just wanted to get it certified and road worthy before deciding what I was going to do with him. I needed new brake cylinders and king pins for mine to pass but, seat belts, extra turn indicators and pretty anything not original was exempt. Emissions testing was exempt as were side mirrors.
As I said, it really depends on where you are getting it certified regardless of the MOT regs. Sooner rather than later would be good advice. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I did read through the new regulations and it appears that a leaking steering box will not pass. I think I will buy some John Deere Stock because their corn head grease is going to be in high demand! Also, they will be obligated to measure and record the drum diameters and the shoe thicknesses. So then there will be discussions about what drum sizes will pass. I see new Chev drums for cars and half tons advertised with a stated maximum oversize limit of .100" and .090". The shoe thicknesses are stated in black and white in the regulations. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Back in the 70's I had to get my 54 3100 inspected in Illinois. I'd leave a 6 pack on the front seat and when it came through the other end of the garage the beer would be gone and there would be a new inspection sticker on the windshield!  Samantha | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Good God It should be that easy today,I know,I remember. But Now with the liability and lawsuit happy tugnutz, most shops want to see if the work/repair was done before they will even Dreeaamm of putting their sticker on. Unless obvious a restored/redone vehicle. steve sr. | | |
