1 members (Hotrod Lincoln), 88 guests, and 5 robots.
Topics128,014
Posts1,055,325
Members48,419
#1161683 04/22/2016 1:30 AM
Not sure I'm calling this part the right name, but it's the parts where the rear leaf springs attach to the rear end. One is tight around the axle housing, the other is very loose. I'm soaking the bolts that hold the halves together so I can take the loose one apart. I assume there should be some kind of gasket between it and the axle housing. Anyone know what the part is called and where I might be able to find new gaskets?
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Hoff #1161687 04/22/2016 1:41 AM
If you have a torque tube, the spring assembly is designed to allow the axle to rotate as the springs go up and down. When they were steel on steel, they could wear at the point where it rotates.
1951 1 Ton Completed
Hoff #1161688 04/22/2016 1:41 AM
What make, year, and series/model truck?
Hoff #1161692 04/22/2016 2:10 AM
It's a 38 Chevy half ton. The side that's loose has worn a lot into the axle housing. Is there anything I can do to repair the damage or at least stop it from getting worse?
1938 Chevy 1/2-ton
Hoff #1161697 04/22/2016 2:39 AM
Not sure if this will help but these are the pieces off a 1946 half ton that I just cleaned and blasted for a bolter. I suspect the two halves that go around the rear housing are held by two screws that go in from the "top" and screw into the bottoms.
Does this help....
http://i140.photobucket.com/albums/r19/LutherParris/Spare%20Parts/46%20rear%20end%20parts%20001.jpg
Hoff #1161703 04/22/2016 2:59 AM
I measured the gap and had a machine shop shave a few thousands off the top and bottom halves. You can mic the axle and figure the wear. I suppose if the axle was really bad you could build it up with weld. Grind etc back to the oem size. The wear is not equal around axle so my fix worked well for me. There are no gaskets.
Hoff #1161707 04/22/2016 3:42 AM
Thank you for the photos and info. I'll let the screws soak for a bit before I try to remove them. The wear on the loose side seems pretty deep, but I'll have a better idea once I remove the parts.
Thanks again!
1938 Chevy 1/2-ton
