4 members (baldeagle, Jon G, Oswald, 1 invisible),
57
Mod | | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 96 Shop Shark | | Shop Shark Joined: Apr 2016 Posts: 96 | I'm curious what types of gas people on here run and what types of additives are used.
I've found a lot of mixed opinions about running regular pump gas.. So what has worked for you? Low octane, high octane? Ethanol, no ethanol? Additives or no additives?
1954 GMC 350-27
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2016 Posts: 96 Shop Shark | | Shop Shark Joined: Apr 2016 Posts: 96 | Is there ethanol in the 87 where you live? We can't get straight has except for 91 in southeastern South Dakota.
1954 GMC 350-27
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Yes , not sure the percent. I think it depends on the time of year.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 10% ethanol is common in NY. I have had no problems (in 12 years).
NC does not require labelling of ethanol content (a very consumer oriented state). | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Winter blend vs summer blend is usually produced by varying the amount of butane. Still, maybe ethanol is also adjusted by season to keep evaporation low? | | | | | Joined: Apr 2016 Posts: 96 Shop Shark | | Shop Shark Joined: Apr 2016 Posts: 96 | around here it's always 10% except e85 which is obviously 85%
This has turned out more unanimous than i thought it might be.
1954 GMC 350-27
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I use 87 octane with 10% ethanol. I have to change the accelerator pump diaphragm in my Carter carburetor about every three years. Other than that, all is well. Carl
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | I just run regular pump gas but, I have noticed both my barracuda and suburban don't like the winter gas near as well as the stuff they sell in the summer. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 87 octane, 10% ethanol. No additives.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | 100%, 91 octane real gas, always! We're lucky in Oklahoma to be able to easily find the real stuff.
| | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | I am lucky to be able to buy non-ethanol 85, 87, and 89 octane. Ethanol is bad stuff for anything older, avoid it if you can.
Daryl
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Ethanol gunks up the old vintage carbs. I also do not like that it starts to deteriorate after 3 months and begins to smell bad, then go bad REAL quick after. If you have one of those edge trimmers for your lawn that you use only twice or three times a year, you can relate. No slam on ethanol because that is for modern cars, but bad for this vintage. Also, bad if you only drive your truck seasonally. IMHO.
So, for those who are confused on what to do. In the 1950s, they used Lead and it had the effect of added lubrication and allowed these engines to run longer. In addition, the timing and 'pinging' problem was better managed. If you are having problems, and ONLY if it bothers you.. go to any small airport and ask the FBO (the operator of the Airport) if you can get gas from them. Then choose 100 (octane) Low Lead. It is expensive, but if that is not your first concern, try it and see if it makes a difference. Here in Kansas, they do not exclude anyone from purchasing their gas. It's commonly referred to as AVGAS.
Controversy isn't the issue here. Your pinging, timing and understanding of the evolution of engines is. Focus on what is best for YOU. Let others whine about each opinion. IMHO
Anyone for discussing DOT5 vs DOT3 brake fluid? How about what Oil to use? LOL! Please nobody blow a gasket! I hear they are not in production anymore. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have been using Sta-Bil gas treatment over the winter for over 10 years (in my lawn mowers and in my Suburban). The Suburban hibernates for about 5 months and starts right up in April/May (since 2004). I have had no carburetor problems in that time. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | X2 on the Sta-bil but I also do not live in a harsh climate. Luckily I can start my stuff up, even the mower, during the winter.....and a nice cruise/ride on a pretty day.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Sta-bil is on my shopping list. Definitely worth a try! | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I just started my truck after sitting since late October and he fired right up. It wasn't much of a winter this year but usually we have serious winter in this part of Canada. For the last fill of the season I fill the tank with ethanol-free gas and pop in half a bottle of Sta-bil and drive home just part him and wait for spring. | | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | Keep in mind, there are 2 different blends of Sta-Bil. You need to use the Sta-Bil for ethanol gas if that's what you're treating. The old 'regular' Sta-Bil doesn't work with ethanol.
Daryl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "If you are storing a gasoline vehicle or piece of equipment for 30 days or longer, we recommend you continue to use STA-BIL® Fuel Stabilizer. It will keep fuel fresh for up to 12 months.
If you are looking for an additive that will help protect your vehicle or equipment from Ethanol-blended fuels, you should be using new STA-BIL® Ethanol Treatment more regularly to help further protect against corrosion, clean your fuel system, and remove water at every fill up." | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Keep in mind, there are 2 different blends of Sta-Bil. You need to use the Sta-Bil for ethanol gas if that's what you're treating. The old 'regular' Sta-Bil doesn't work with ethanol. Which old 'regular' Sta-Bil doesn't work with ethanol? " DOES THE ORIGINAL STA-BIL® FUEL STABILIZER NO LONGER WORK WITH ETHANOL FUELS?
This is absolutely NOT true. STA-BIL® Fuel Stabilizer is effective in storing gasoline for up to 12 months in ALL Ethanol blended fuels, up to E-85. It prevents gum and varnish formation/build-up caused by the breakdown of fuel and also helps prevent corrosion from moisture/humidity during storage. " http://www.goldeagle.com/brands/sta-bil-faqs | | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | Good work! You've done some research that proves what I've been told is not accurate. Thanks for taking the time TC!!
Daryl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Your posts had me worried, Daryl You caused me to wonder if my use of Sta-Bil every winter was just a mindless practice/habit. Thanks for making me look it up. It is hard to prove it is helping over the winter. It is possible that I would have no problems if I stopped using it? By the way, I found it odd that only one product refers to ethanol on their Sta-Bil products-page. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I use 87octane pump gas, except for that last tank before winter storage. I run the tank as empty as I dare and go fill it up with non-ethanol premium. I do the same for the motorcycles, the chain saw and the wood chipper. The ethanol can create tiny balls when exposed to water in storage. The balls are small enough to plug up idle circuits in carburetors. This proved a real pain on my Gold Wing which takes about three days work to get to the carbs to clean them. Never again. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One can sometimes get non-alcohol fuel(80 octane) at your small, local airport.
Ed
| | | | | Joined: Apr 2016 Posts: 12 New Guy | | New Guy Joined: Apr 2016 Posts: 12 | I live in NOLA area and avoid ethanol gas if possible. Octane really depends on performance build on engine, my old custom Harley Shovelhead I use only premium. (and plan to do same when I finish building engine for my stovebolt.) Reason I avoid ethanol if possible is because I have personally seen how it attracts water causing problems in gas tanks and float bowls and NOT good for older rubber products. I read anything built prior to 2012 is NOT ethanol friendly. | | |
