| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | As a guy contemplating doing my own painting of my truck after some of the sheet metal welding is completed by a body shop I was wondering, how much paint is required for a typical truck? I would be using an HVLP gun attached to my compressor (6.25hp, 30 Gal tank, 130 psi max). After seeing the body shop estimate (ouch!!) I am trying to save money where I can. This is to be a driver truck not a trailer queen and for what he wants, I'm not sure I could in good conscious drive it after the work is done. Please advise. Thanks.
Steve 55 1st Series 3/4 ton
| | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | It depends on what color and what type of paint. A solid color will use less paint. My 37 took a gallon and a half to cover everything except the fenders and running boards. I used 2000 Honda Huntsman Green Pearl Metalic over a dark grey sealer. The paint was kinda thin so I had to really pile it on to get a good even coat with a good spray pattern. The black for the fenders will cover almost anything with one or two coats. | | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | I painted my '53 about 5 years ago. It is Burgandy Maroon with black fenders and grill. The fenders and grill took about 1-1/2 quarts and the cab and bed took about 1 gallon. That figures about right since the catalogs generally say to figure about 1-1/2 gallons for the whole truck. I just painted the interior of the cab and it took 2 quarts to do it right. What I hadn't counted on was the cost of the additives (reducer was about $30 and hardener was $55 for just a pint! You need both, though, if you want to do it right and have it dry in a decent amount of time. The interior I just did was Champaign which was the original for that year. I did it in Acrylic Enamel which is supposed to be hard for an amateur to use. I had no runs and no orange peel and am feeling pretty proud of myself. But I also mixed it exactly as the directions said with the reducer and hardener. I'm fixing to repaint the exterior because the guy I had do it for me a few years ago left a few runs. It also wasn't the right color for original burgandy maroon. I'm thinking of trying something different. This is a little long-winded, but don't forget those other additives in figuring your cost. Also, primer isn't cheap. Good luck.  | | | | | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | Thanks for the info. I wasn't sure about the reducer and hardener so that is good info to have now. I will most likely be using an acrylic enamel as well in something as close to the original Juniper Green that I can find.
| | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | My paint for the interior came from Chevy Duty and was manufactured by Sherwin Williams. They recommend using reducer and hardener from the same manufacturer. The ratio was 8:4:1 with 8 parts paint to 4 parts reducer to 1 part hardener. Also, if you're looking for Juniper Green or any paint close to the original, you might look at Jim Carter or Chevy Duty. I can't find anyone that has Burgundy Maroon except Carter. However, when I had my paint mixed last time I painted it, I didn't go to an old car/truck store. The paint was too red and it taught me a lesson. If you want it right, go to the vintage parts places and buy it there. | | |
