| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 19 Junior Member | | Junior Member Joined: Nov 2003 Posts: 19 | When a patch panel is applied and you are butt welding, I know you are supposed to weld small areas at a time spacing them every inch or so. Once you have it all welded,still having the gaps, do you completely weld up every gap till no holes remain or is it ok to leave some tiny gaps and fill in later when you do the body filler work. | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | Fill them in, only leaving the gap's to keep the heat down when welding in the panel initially to stop distortion, should be a solid weld when finished, Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
