2 members (Wooley, Hotrod Lincoln), 81 guests, and 3 robots.
Topics128,096
Posts1,056,488
Members48,444
#1159486 04/10/2016 2:17 AM
I tracked down the truck that sat in my yard growing up, a 1955 Napco 4WD 1/2 ton!
It has the V8(v code, non orig motor)
Rockwell Tcase/ with 3/4 ton front axle
Rust(character).
I aim to restore, as original as possible! This will stay in the family as long as I'm alive, I plan to take it on the trails, camping, to work on occasion. I have read a ton on here, and got a lot of help already from others posts, thank you!
I got the motor fired up after sitting 20+ years, a 70's 327, very healthy, drove it around the yard with no brakes, she may stay for a while. I started on brakes, was going to rebuild the master cylinder, but the bore is far too corroded to ethically put back in :)
-Trevor
Big Bolt Forum Moderator
welcome to the site! Sounds like a great truck, and cool it was in your yard growing up!
Mike
Leo Offline
Moderator
Moderator
Welcome Trevor. Sounds like a cool truck, nothing wrong with a 327, but I don't think they made those in the 70s, just the 60s.
Be sure about those brakes, they can corrode from the inside so it could be worse than you think. Good luck with it.
Leo
Welcome to the Stovebolt. How about a picture or two when you get it all figured out. See ya in the garage forums.
Welcome Trevor.....You have yourself a fine truck to own! I'm envious...........
1959 3100 Apache Fleetside
Welcome Trevor,
AHHH... the '55 2nd series NAPCO with the Rockwell transfer case! You WILL have lots of fun with this truck, (and after it is on the road) more questions from admirers asking what it is!!! Believe me.......... I know..... I own one! A good handful of NAPCOs out there but they have the Spicer set up.......Rockwells are few and far between!!!! Good Luck with it, and if ya have some questions, send me a message. More than happy to help!
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
