0 members (), 361 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
#1159356 04/09/2016 1:43 PM
I just installed my rebuilt 59 235 engine back in my truck. I cranked it up and started running it at a mid RPM break-in period as requested by my engine builder. Afterwards, I noticed an exhaust leak on the side of my exhaust at the moving warm up mechanism/device (I don't know what it is called but it helps send heat back to the engine for warm-up). I am wondering if I can eliminate that device or leave it in place and seal off both ends to stop my exhaust leak? It is leaking on the side with the large counterbalance weight device. Leaking where the stem passes through the manifold. Any suggestions would be appreciated!!
1950 Chevy 3100
In the DITY Gallery
77 International Scout ll
96 F-150 ext cab 4x4
2000 Tahoe
2011 chevy 3/4 ton 4x4
You are referring to the heat riser, it's best to keep it, they help in cool damp climates.
If you are mechanically inclined, you can take the flap out, with some work, and put tight fitting bushing in the manifold to help seal the leaks. The flap is welded on the shaft and requires some grinding, it would also will require some welding to put it back. It's about as much work to take it out and plug the holes as it is to fix the holes and repair it for good.
Crusing in the Passing Lane
Bronze/brass bushings are available in common sizes. Definitely fix to operate as designed.
Ed
Here is another option - if your pivot holes are not too wallowed out?
Some good pics on dennys site
...link...
Shows where the shaft is spot welded
...pic...
