0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Should I just use por 15 and then paint it or use some kind of undercoatiing product. I have the floor boards almost done and need to know what to seal them with before the rust takes over. I'd prefer some kind of brush on product as I have to crawl under the truck to do it and dragging the paint gun under there is a real PIA.
Craig
Still trying to get ole Betsy back on the road.
You can't beat epoxy primer.
It works with a brush too.
Give me ambiguity
or give me something else
I have used POR15 with good results, prep is the most important thing no matter what you use.
just-a-hacker
'49 3100 before '99
I used leftover enamel paint, Valspar farm and implement paint, then topped it with and undercoating made by Permatex. The undercoating though came out of the spray can runny. Then when it dried to a certain degree, rolled it with a small nap paint roller, looks good to me and low budget! Mike
I like the POR15. Use old clothes, throw away brushes and wear a mask as well as hove some air movement. Its good stuff and does not fade unless in direct sunlight. Did one of my chassis in it years ago and its still tough, slick and shiny.
....Where you have a ground connected to the body/frame be SURE you grind it off to get a good ground.
i will be using spray on bedliner on mine, looks similar to the tar-like undercoating from the factory.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Okay, Lots of good info. I think I'll go with the POR 15 and some type of rubberized undercoating for the sound deading qualities.
Alvin..latex or nitrile gloves...you forgot the gloves man!
(I'm speaking from experience of course...) wink
Good advice on the chassis grounds though.
Like Alvin I favoured POR-15,my truck's an all year driver (my daily) and as such suffers everything a Scottish winter can throw at it,including salt.
I'm pleased to say after two such winters and 6000+ miles it's holding up well.
More pix on Flickr.
POR-15 for my last two trucks, too.
....and don't forget the GLOVES. Thanks Jock.
It takes days and weeks to "wear it off".
