9 members (JW51, Rusted Nut, jmoore, 2-Ton, Gdads51, GA Boy, cmayna, Hanks custodian, 1 invisible), 77 guests, and 4 robots.
Topics128,169
Posts1,057,041
Members48,458
Does anyone know if the local FLAPS (NAPA, etc.) carries the seals for the rear axle. Mine are leaking and I'd like to get it fixed before it gets in the brakes. Part numbers would be awesome.
I did see these at Chevs of the 40s but wanted to pick them up locally IF possible. Thanks!
Chevs of 40s rear axle seals
1946 Chevrolet 1/2-ton
More pix on Photobucket
Rock Auto showed one available. Part number SKF 14875 for $2.40 but you may check at NAPA and see what that number will cross to. I suspect that seal was used for many years.
3B Offline
Hy Big Tee, the part number I came up with is National 5801, that crosses to Napa/C/R NOS18695 $32.99 reserve online price at Napa, hope that helps.
Thank you everyone!
By the way, I found these seals (National 414045) on Amazon for $4.95 each.
http://www.amazon.com/National-Oil-...ox_sc_act_title_2&smid=ATVPDKIKX0DER
