0 members (),
93
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Does anyone know if the local FLAPS (NAPA, etc.) carries the seals for the rear axle. Mine are leaking and I'd like to get it fixed before it gets in the brakes. Part numbers would be awesome. I did see these at Chevs of the 40s but wanted to pick them up locally IF possible. Thanks! Chevs of 40s rear axle seals | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Rock Auto showed one available. Part number SKF 14875 for $2.40 but you may check at NAPA and see what that number will cross to. I suspect that seal was used for many years.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Big Tee, the part number I came up with is National 5801, that crosses to Napa/C/R NOS18695 $32.99 reserve online price at Napa, hope that helps. | | | | | Joined: Oct 2008 Posts: 310 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 310 |
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | | | |
