4 members (52Carl, Hanks custodian, Hugh63c10, Ponchogl), 122 guests, and 1 robot.
Topics128,052
Posts1,055,771
#1157554 03/30/2016 2:26 AM
The vacuum advance went in my 1953 235. We found a donor one from a 58 (I think) but I want to know of its compatible or the range of years that would be compatable.(ie.same angle of advance).
Alexmck #1157556 03/30/2016 2:38 AM
They might be different, and the difference might make a performance difference, but I doubt that - I have used a 1960 unit on a 1954 truck.
Alexmck #1157576 03/30/2016 3:35 AM
Is the 58 advance passenger or truck?
The passenger car advances are angled to clear the motor mounts.
Although there may be a slight difference in advance between the two,if they are both passenger car advances you can change the springs between the two,other than that it should work.
My Blog
Alexmck #1157577 03/30/2016 3:35 AM
Since the vacuum advance only functions at very light-throttle cruise, it's pretty forgiving if it's a degree or two off. As soon as the throttle gets opened to accelerate or pass, the extra advance from the vacuum unit goes away and only initial and centrifugal advance is in play.
Alexmck #1157600 03/30/2016 9:15 AM
I usually just run without a vacuum control like the larger trucks did. More advance at light throttle is supposed to help fuel economy, but I can't notice the difference and the vacuum control is just one more thing to cause trouble. Of course, I drive these old things like we did 50 years ago. Either full throttle or coasting.
Alexmck #1157610 03/30/2016 2:09 PM
Available from several vendors:
http://www.classicparts.com/1937-62-Vacuum-Advance-6-Cylinder/productinfo/83%2D274/#.VvvPtfA8KrU vacuum advance
Alexmck #1157716 03/31/2016 1:38 AM
Can we "rebuild" an advance ourselves?? Whats the best way to test an advance that is not on the vehicle?
...don't meant to hijack post but maybe its appropriate with this thread?
Alexmck #1157730 03/31/2016 2:18 AM
Make sure your bracket is compatible with the vac advance...
Some use a small step bolt, some use a tang, and some are angled as stated above
It would be hard to rebuild with out special tooling.
As far as checking condition. The main thing that fails is the diaphragm. If you have a Mityvac you can check for leaks in the diaphragm. Or the old fashion way is to suck on it with your mouth and then put your tong over the hole and see that it holds vacuum.
My Blog
Alexmck #1157738 03/31/2016 2:43 AM
Back when most mechanics were smokers, we would blow a puff of cigarette smoke into the nipple. If smoke came out around the operating rod, the diaphragm was bad.
Alexmck #1157742 03/31/2016 2:52 AM
Thanks... Jerry, since I don't smoke I'll have to get my 83 year old father in law to blow a puff into it. He takes his oxygen mask off long enough to puff a Pall Mall....not kidding!
Alexmck #1157779 03/31/2016 1:28 PM
I cold-turkey stopped smoking (3 packs a day) in 1977, Jerry
I would also have a hard time finding a friend to do it for me.
Alexmck #1157784 03/31/2016 2:31 PM
When I walked into an emergency room with chest pains about 15 years ago, I left half a pack of Winston Lights in the console of the Cadillac I was driving. I was in the process of having a heart attack. Two stents and a bunch of cardiac rehab made me make some pretty drastic lifestyle changes. The car is parked out in the pasture now, so if I ever really need a smoke, those cigarettes are still there! I kinda doubt that's going to happen, though!
Alexmck #1158791 04/06/2016 7:03 AM
1 Offline
I ran on a 3000 mile trip with a failed Vacuum advance on my 3800. It had an off-idle hesitation that was annoying but I figured I could live with it. What I didn't realize was that running at light throttle and retarded timing raises exhaust temperature, which overheated the exhaust manifold and burned out the manifold gaskets and the exhaust pipe flange gaskets (Fenton). I had to fix it on the street in front of my sister's house in Salt Lake City in the snow in early November, which was a pain. NAPA had the gaskets and the advance unit and I bought both. I could have saved myself a bundle of trouble by replacing the Vacuum advance right away.
1951 3800 1-ton
In the DITY Gallery
Alexmck #1158894 04/06/2016 10:11 PM
U
U Offline
Originally Posted by Uncle Brad
For no other reason than to have pictures for reference, here is what the inside of a vacuum advance looks like.
Alvin- a friend & I have not abandoned rebuilding a vacuum advance, but the attempt was pretty much halted 2 years ago as soon as I bought one for $30...
Brad
Wrench Fetcher, PhD
Alexmck #1158959 04/07/2016 4:40 AM
Thanks Brad. I have two so I'll give them Jerry's "smoke" test when I find someone who smokes.
(Pa in law went home today)...not sure for how long?
Edit: if mine is bad I'll take one apart just for the heck of it. I like to see how things work.
Alexmck #1158982 04/07/2016 1:19 PM
Can you apply some vacuum to the outlet and see if it holds to test them out?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #1158985 04/07/2016 1:46 PM
Originally Posted by Pre '68 Dave
. . . Or the old fashion way is to suck on it with your mouth and then put your tong[tongue] over the hole and see that it holds vacuum.
Alexmck #1158993 04/07/2016 2:57 PM
The little hand-pumped MityVac unit is the best way to check any vacuum operated device, and it doubles as a very effective brake bleeder with the right accessories. Cheap on Ebay, also!
