| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 43 | I was hoping you guys could recommend a good source of rubber boots for the floor pedals on my 1950 3100. Most of the imported crap won't last 6 months. Thanks. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Look for machine "bellows" at this website or at other machinery or tractor shops. This is if you want them to "last"... they are fit & function, but not original. Brad Wrench Fetcher, PhD | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike, That boot (shown upside-down) is held under the floor-hole with this retainer. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | OK, that's not what the TF truck use. The boot looked smaller than what we TF guys need, our trim ring is about a 4" x 6" rectangle (had to ask to be sure). Thanks, Mike B  | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I saw a picture of one with the screws, unless the screws are super long, it is quite a bit smaller than the TF park brake boot we all need. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I wonder where 6XChevy is. I am curious what he considers to be "rubber boots for the floor pedals." Carl
| | | | | Joined: Dec 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 43 | I guess I should have used the terms grommets or seals. I am looking to replace the grommets around all the foot pedals and haven't had much luck with the imported stuff most vendors sell. Appreciate it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are you referring to a 1950 Chevrolet light truck? If they are not like to parts at the links I posted above, would you please post links to photos of the areas where the grommets are located? Does your left floorboard ("toe board"), where the pedals go through the floor/wall/board, look like this ? | | | | | Joined: Dec 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 43 | I am referring to my 1950 AD, I am thinking about trying the starter bellows seal and parking brake boot from Chevys of the 40's. I guess their products are as good as any available. Does the starter pedal button screw off? Do you use a pipe wrench to loosen it? Appreciate it. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Yes, the button screws off. Mine has two flats so you can get a wrench on it, you will have to hold the rod with pipe wrench or vise grips. If you can't get a wrench on the button you may have to use two pipe wrenches. good luck root | | |
