2 members (Otto Skorzeny, dt235sd), 122 guests, and 1 robot.
Topics128,052
Posts1,055,719
#1156861 03/25/2016 11:52 PM
I was hoping you guys could recommend a good source of rubber boots for the floor pedals on my 1950 3100. Most of the imported crap won't last 6 months. Thanks.
6XChevy #1157083 03/27/2016 2:46 PM
U
U Offline
Look for machine "bellows" at this website or at other machinery or tractor shops.
This is if you want them to "last"... they are fit & function, but not original.
Brad
Wrench Fetcher, PhD
6XChevy #1157097 03/27/2016 4:16 PM
Was there a boot/bellows for the (1950 3100):
- accelerator/gas pedal rod
- brake & clutch pedal rods
There was a bellows/seal/boot on the:
- starter pedal rod
- parking brake pedal/rod
6XChevy #1157175 03/28/2016 12:42 AM
Tim,
Are you familiar with this AD boot, is this for a parking brake lever?
https://www.chevsofthe40s.com/detail/6644/Chevrolet_Emergency_Brake_Pedal_Boot_Under_Floor_.html
Look a lot like the TF boot, just not sure if it's big enough...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
6XChevy #1157179 03/28/2016 1:08 AM
Mike,
That boot (shown upside-down) is held under the floor-hole with this retainer.
6XChevy #1157185 03/28/2016 1:53 AM
OK, that's not what the TF truck use. The boot looked smaller than what we TF guys need, our trim ring is about a 4" x 6" rectangle (had to ask to be sure).
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
6XChevy #1157186 03/28/2016 1:55 AM
Big Bolt Forum Moderator
I saw a picture of one with the screws, unless the screws are super long, it is quite a bit smaller than the TF park brake boot we all need.
Mike
6XChevy #1157372 03/29/2016 2:23 AM
I wonder where 6XChevy is. I am curious what he considers to be "rubber boots for the floor pedals."
Carl
6XChevy #1157612 03/30/2016 2:18 PM
I guess I should have used the terms grommets or seals. I am looking to replace the grommets around all the foot pedals and haven't had much luck with the imported stuff most vendors sell. Appreciate it.
6XChevy #1157618 03/30/2016 2:46 PM
Are you referring to a 1950 Chevrolet light truck?
If they are not like to parts at the links I posted above, would you please post links to photos of the areas where the grommets are located?
Does your left floorboard ("toe board"), where the pedals go through the floor/wall/board, look like this ?
6XChevy #1157627 03/30/2016 3:53 PM
I am referring to my 1950 AD, I am thinking about trying the starter bellows seal and parking brake boot from Chevys of the 40's. I guess their products are as good as any available. Does the starter pedal button screw off? Do you use a pipe wrench to loosen it? Appreciate it.
6XChevy #1157685 03/30/2016 11:50 PM
Yes, the button screws off. Mine has two flats so you can get a wrench on it, you will have to hold the rod with pipe wrench or vise grips. If you can't get a wrench on the button you may have to use two pipe wrenches. good luck root
