| | | Forums66 Topics128,162 Posts1,056,937 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Can somebody tell me what year AD has the gas tank UNDER the bed? I'm looking for the no.# 2 cross sill that goes over the tank. It has a "hump" in it to clear the tank. I need to know the correct year so I can go look for one. My 52 has TWO tanks...one behind the seat and one under the bed...both stock tanks. :confused: THANKS! | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Look under 1-ton trucks and suburbans
| | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | '47 and '48 pickups also had the gas tank under the bed.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Russntustin,
What size '52 pick-up are you working with? Size might matter when talking about the frame braces for fuel tanks.
As OleBlue said, '47.5-'48 pick-ups and all 47.5-55.5 1/2 ton suburbans and panel trucks had fuel tanks between the frame (passenger side, forward of the rear axle). The suburban/panel trucks have two frame braces that go over the tank (maybe someone else knows if the 47.5-48 pickup had the same braces).
Tim | | | | | Joined: Dec 2002 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 86 | I have a 48 3/4 ton. the gas tank is under the bed.
47.5 Loadmaster 5 window 48 Chevy 3600 69 GTO convertible | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | I should have said...It's a 1/2 ton five window stepside.Strange,huh?! The tank in the back is stock,but when I got the truck,it didn't have the cross sills.a'regular' sill won't work in that area of the gas tank w/o modification. | | |
