3 members (TUTS 59, Southerntruck, WICruiser), 216 guests, and 3 robots.
Topics128,162
Posts1,056,942
Members48,458
#115722 03/05/2003 2:39 PM
Can somebody tell me what year AD has the gas tank UNDER the bed? I'm looking for the no.# 2 cross sill that goes over the tank. It has a "hump" in it to clear the tank. I need to know the correct year so I can go look for one. My 52 has TWO tanks...one behind the seat and one under the bed...both stock tanks. :confused:
Look under 1-ton trucks and suburbans smile
'47 and '48 pickups also had the gas tank under the bed.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#115725 03/05/2003 10:57 PM
Russntustin,
What size '52 pick-up are you working with? Size might matter when talking about the frame braces for fuel tanks.
As OleBlue said, '47.5-'48 pick-ups and all 47.5-55.5 1/2 ton suburbans and panel trucks had fuel tanks between the frame (passenger side, forward of the rear axle). The suburban/panel trucks have two frame braces that go over the tank (maybe someone else knows if the 47.5-48 pickup had the same braces).
Tim
I have a 48 3/4 ton. the gas tank is under the bed.
47.5 Loadmaster 5 window
48 Chevy 3600
69 GTO convertible
I should have said...It's a 1/2 ton five window stepside.Strange,huh?! The tank in the back is stock,but when I got the truck,it didn't have the cross sills.a'regular' sill won't work in that area of the gas tank w/o modification.
