0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#1157203 03/28/2016 3:47 AM
I am starting the rebuild on my box. Both rear stake pockets are beyond repair. I have new ones, but can't see any spot welds/welds on the old ones. I hate wrecking more than I have to, has anyone cut them off and left a layer of old tin and just weld the new one to this? Any suggestions would be welcome. Thanks
What year?
1946 1/2 ton Chevrolet?
Don't know the accessability of the area, but if you carefully hand sand the flanges with a medium emery cloth on a flat block, when most of the paint and rust are removed and you are seeing bare metal, the witness marks of the spot welds will become visible. They may be faint, but a pattern will emerge because they will retain some paint/rust.
What Jim ^ said.
Or you can drive a chisel between the bedside and stake pocket, which will leave a somewhat bigger depression at the spot welds that you'll be able to see. Don't go too crazy and bend the bedside too much.
I had to remove one of mine which was both rusted and crunched.
