0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 16 New Guy | | New Guy Joined: Jul 2013 Posts: 16 | Does anyone have a picture of what the "bend" should look like under the side cover for the copper oil supply line?
Thanks! Keith
1951 3600 Chevrolet
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 |
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just made one up for my 1940 216. I didn't end up with the perfect bends as per instructions but I got the job done. Coming out of the block, it has to go up to avoid the indentations in the lower part of the cover. then it goes across and after curving it goes up through the dedicated hole in the head.
Have you got the GM instructions? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | All USA-built 216 had the "tall" side covers.
Later-year Canadian-built 216s (1950-53?) had short side covers. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is exactly what I was describing.
Tim, I think it was 50 to 52. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I don't have a photo but it's just a bit of an S bend to allow the head & block to grow & shrink without stressing the line. I wouldn't worry about "correct appearance". No judge is going to pull your side cover.
