1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | Im trying to find out what the wording was on the L O F glass bug on original door glass out of early fifty's if any body has any. Driver and passenger side also to see witch side is readable from inside or out. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Wrench Fetcher, PhD | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | As long as the glass was flat Chevrolet only needed to have one side made (fits both sides), so the LOF would be facing the same way. One reads from the inside and the other from the outside. Once they started using curved glass I believe Tim is right, readable from the outside. Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | Do you think they would of gone as far as facing the outside on one side of vehicle or just wherever.
This is what I have so far. On the windshield has The word Plate ,on the vent glass and on center rear has the word Sheet, I don't have any old glass for the Doors. Both of mine are PPG Glass and I know one of them had be replaced. I'm thing they would of been the sheet glass. On the five window cabs the corner glass said Solid | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As Mike posted, they marked the glass on the same side/location no matter which side they were installed.
So, they did not have to think which side faced which way, they just installed it.
I am not near my Suburban, but I have the E-Z-Eye (an L-O-F brand) markings and they are supposedly the original orientation.
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | David, Plate and Sheet refer to the glass thickness. If I remember right, Plate was 1/4", sheet was 3/16". Plate was made of two pieces of 1/8", Sheet had one 1/8" and one 1/16". The glass had the lamination in between. This is where the problem with new door glasses dragging in the run channels comes from, Safety Sheet is a thing of the past. Your curved quarter glasses are tempered, hence "Solid" (not laminated). Just some useless info from an old glass guy. John | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | David, Plate and Sheet refer to the glass thickness. If I remember right, Plate was 1/4", sheet was 3/16". Plate was made of two pieces of 1/8", Sheet had one 1/8" and one 1/16". The glass had the lamination in between. This is where the problem with new door glasses dragging in the run channels comes from, Safety Sheet is a thing of the past. Your curved quarter glasses are tempered, hence "Solid" (not laminated). Just some useless info from an old glass guy. John | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Tim, thanks for the 2nd link. I'd forgot about the different lamination thickness, but as soon as I read it, it came back. .015" isn't much, but cutting the lamination on sheet on a cold day was sure easier than .030! Ah. the good old days. John | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Tim, thanks for the 2nd link. I'd forgot about the different lamination thickness, but as soon as I read it, it came back. .015" isn't much, but cutting the lamination on sheet on a cold day was sure easier than .030! Ah. the good old days. John | | |
