0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#1153063 03/02/2016 9:56 PM
Im trying to find out what the wording was on the L O F glass bug on original door glass out of early fifty's if any body has any. Driver and passenger side also to see witch side is readable from inside or out.
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
David Sr #1153066 03/02/2016 10:02 PM
U
U Offline
Libbey Owens Ford?
Brad
Wrench Fetcher, PhD
David Sr #1153085 03/02/2016 11:51 PM
Here is an old post on L-O-F glass.
Their E-Z-Eye tinted glass was an option starting in 1953.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/998050/Glass_Date_coding.html#Post998050
I think I was told that the marking were readable from the outside (so there was right side glass and left side glass).
David Sr #1153118 03/03/2016 2:40 AM
As long as the glass was flat Chevrolet only needed to have one side made (fits both sides), so the LOF would be facing the same way. One reads from the inside and the other from the outside.
Once they started using curved glass I believe Tim is right, readable from the outside.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
David Sr #1153121 03/03/2016 2:45 AM
Thanks, Mike
David Sr #1153179 03/03/2016 11:24 AM
Do you think they would of gone as far as facing the outside on one side of vehicle or just wherever.
This is what I have so far. On the windshield has The word Plate ,on the vent glass and on center rear has the word Sheet, I don't have any old glass for the Doors. Both of mine are PPG Glass and I know one of them had be replaced. I'm thing they would of been the sheet glass. On the five window cabs the corner glass said Solid
David
David Sr #1153189 03/03/2016 2:34 PM
As Mike posted, they marked the glass on the same side/location no matter which side they were installed.
So, they did not have to think which side faced which way, they just installed it.
I am not near my Suburban, but I have the E-Z-Eye (an L-O-F brand) markings and they are supposedly the original orientation.
David Sr #1155078 03/15/2016 3:08 AM
David, Plate and Sheet refer to the glass thickness. If I remember right, Plate was 1/4", sheet was 3/16". Plate was made of two pieces of 1/8", Sheet had one 1/8" and one 1/16". The glass had the lamination in between. This is where the problem with new door glasses dragging in the run channels comes from, Safety Sheet is a thing of the past. Your curved quarter glasses are tempered, hence "Solid" (not laminated). Just some useless info from an old glass guy. John
David Sr #1155079 03/15/2016 3:09 AM
David Sr #1155091 03/15/2016 3:24 AM
David Sr #1155263 03/16/2016 3:18 AM
Tim, thanks for the 2nd link. I'd forgot about the different lamination thickness, but as soon as I read it, it came back. .015" isn't much, but cutting the lamination on sheet on a cold day was sure easier than .030! Ah. the good old days. John
David Sr #1155264 03/16/2016 3:19 AM
Moderated by  ndkid275, Phak1
